[ZR1] K+N 63-3080 Air Intake
2. Depending on the power level you are at it might not give you much
If you just port your stock snout with a 2.6 pulley installed then I have used an attack blue filter in the stock airbox with great results for much less $$. You can get a ported snout with pulley plus the filter and pay for the install as the same money you would spend on the K&N by itself. But the gains would be about 70rwhp/70rwtq with a tune. Also, I recommend TR7IX plugs when increasing the boost for protection against detonation - stock number 3690 at your local auto parts store.
Cheers!
1. You will need a tune to benefit (warranty gone)
Cheers!
Cheers!
