C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Any thoughts on what I would run?
Old 08-25-2013, 05:33 AM
bigterpsfan
bigterpsfan's Avatar
Default Any thoughts on what I would run?
I have never run my car at the track. I have ~ 555whp and 493wtq on 345/285 PSS tires (new). What do you think I would run with some practice? I am guessing low 11s and 10.7ish on a track tire. Sound about right? Car is a 2009 Z 1LZ
Old 08-25-2013, 09:31 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
That would be around average in decent weather on a good track. Great driver/weather could go a lot fast, poor track, poor driver a lot slower.
Old 08-25-2013, 10:24 AM
LFZ
LFZ's Avatar
You've never run at the track.....then I'd say 12.5-12.2 all day.
Old 08-25-2013, 11:55 AM
Mr. Gizmo
Mr. Gizmo's Avatar
there is 2009 z in the for sale section -- 100% bone stock. guy has a video of that car running 11.59 at 122 or 123 mph.- Bone stock these things make 440-460rwhp on average.
The real tale of hp is MPH. Too many variables on the ET- driver skill, 60 ft times etc etc. at 555rwhp your are 30-50 more rwph over a stock zr1. You should be at 130mph plus in the quarter which would validate your claim of 555 rwhp.
Old 08-30-2013, 09:33 PM
bigterpsfan
Anyone else? I am talking ideal driver/conditions with track tire and street tire. The car seems to pull extremely hard above 3500rpms.
Old 08-30-2013, 09:49 PM
FNBADAZ06
FNBADAZ06's Avatar
The car has the power to run mid-upper 10's with traction and driver execution.
You, as the driver, with no experieince piloting a C6 Z06 of any power level down the track, I'm going to say a humbling 11.7-12.2
Old 08-31-2013, 12:39 AM
Mark Wade
Mark Wade's Avatar
Very good blog as im going to drag mine moro first time , 08 z, 3lz , according to wikipedia 12.2 off factory floor but as you say being a new driver i will be lucky to better that ,we are at sea level here so apparently that helps abit ,fresh engine 1400kms so dont want to thrash it too hard ,anyway one question would i still be in 4th gear going over the top or going into 5th any advise much appreciated im nervous as heck i can tell you.
Old 08-31-2013, 07:05 AM
ctsv510
ctsv510's Avatar
3rd gear goes to 123 ish so you should just hit be hitting 4th before you cross.
Old 08-31-2013, 08:17 AM
avalonandl
avalonandl's Avatar
Launching is the total key. Just remember there are lots of videos on this forum of an owner taking his vette into the guardrail the first time around.
The factory clutches need time to cool down between runs too.
Good luck
Avalon
Old 08-31-2013, 11:55 AM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
4th gear actually goes to well into 130's.... we can a car before and stayed in 3rd just raised the limiter to 7300 and the car trapped 138
Old 08-31-2013, 12:09 PM
HOXXOH
HOXXOH's Avatar
Received 2,060 Likes on 1,505 Posts
Of course, you mean after the first few practice passes in the 13's and 14's.
I watched a first timer with a ZR1 make a half-dozen passes before I had a little talk with him and then he finally made one in the high 12's.
It's hard for newbies to grasp, that without a bit of seat time you don't go WOT quickly and that if you do get squirrly to abort the run.
Old 08-31-2013, 12:16 PM
chempowr
chempowr's Avatar
Run it and let us know. It's hard to say with all the variables like track prep and driver to be the most important IMO. Also modded cars perform differently from what would be expected alot of the time. Some times average power is sacrificed for peak power when tuning or vice versa. Run it a bunch and good luck. hopefully yours is the latter. My stock Z on stock tires ran 11.638. That was my best. My average time is much slower sadly. I hit 11.3 with some old road race rears on (Hoisier A6s).
Old 09-01-2013, 02:30 AM
Mark Wade
Mark Wade's Avatar
Hi guys just reporting in from fathers day drags here in auckland New zealand ,my first run 14.4 sec 13.5 third 12.79 @ 116 mph so i dialed in 12.7 for my eliminations went 2 more rounds before i stuffed up ,i had a 0.00 reaction time which i am proud of ,so basically got faster as day went on , but 1 question please i had traction turned off but 1 of my runs full noise in third the motor shut down for a split second and the message said recalibrating active handling still run a 12.8 , any reason why that happened ,other than that neat fun i was in with A group were i was racing guys with tunnel rams blowers so was pleasantly surprised they were only mid to high 12s anyway thanks for the tips oh yeh i also dropped my tyres to 22lbs seemed to make big difference by for now mark
Old 09-01-2013, 11:46 AM
chempowr
chempowr's Avatar
Mark - what elevation s your track at? If you are above sea level that will also effect power and ET. I noticed your MPH is down (116). Even if traction limited, most can still get a decent mph out of te run 119+ unless elevation is robbing power. NHRA publishes correction factors due to track elevation.
Old 09-01-2013, 04:03 PM
HOXXOH
HOXXOH's Avatar
Congrats on quickly learning the basic launch technique in only 2 passes. It'll even get better with seat time.
I couldn't help laughing about the "If" part of the sea level, when you really meant it's the amount above that affects power.
Old 09-02-2013, 01:08 AM
Mark Wade
Mark Wade's Avatar
We are right on sea level here when the tide comes in the area gets wetter , no one knows why that active handling thing happened ,be really good to know so i can sort it for next time cheers boys
Old 09-02-2013, 09:10 AM
edmundu
edmundu's Avatar
C'mon Fran, that isn't the whole story....raising the rpm by 300, will only give you perhaps 5-6mph, not 15.
You had much taller tires on it as well, didn't you?
To Any thoughts on what I would run?
Quick Reply: [Z06] Any thoughts on what I would run?
