[Z06] Tremec transmission
Tremec transmission
Hello all. I need some help here figuring out exactly what trans I have here. I have some numbers on it and can't seem to figure out which trans it is. Listed below are the numbers. I can't figure out how to post pics from my phone on here, so I hope the numbers are good enough.
Drivers side of trans: 155126695
CUCA-3351
ID Tag bolted to pass side:
125744781 E0652
TUET 4093 AD 06528
Rear diff: 6250044290
CUCA-3351
125744781 E0652
TUET 4093 AD 06528
What year Z06? Do you have nay reason to believe it is not the factory stock transmission?
The Factory transmissions were the T56 and the T6060. I think the first was for 2006-7 and the latter 2008 to date although it may have started being used in 2009 (My July 2008 build MY 09 is a TR6060.
http://www.hotrodders.com/forum/trem...mw-225043.html
http://www.hotrodders.com/forum/trem...nglepost4.html
From google search. But car year would tell you unless someone upgraded.
Trans is a t56.Are you are asking what diff is in it? Specifically what rear end gears or what?
Is the car a z51? That would answer that if you know it is the original trans. Look for the drilled brake rotors, or check the option sticker for z51.
