[Z06] LS7 ported heads
LS7 ported heads
Hey guys,
I am a new member of the Forum as well as new member of the Corvette(Z06) family.
My question is how much gain from porting the stock LS7 heads. All the valve train issues have been corrected already but the heads was not ported. Trying to find out if its worth having it done.
Thanks!
Thanks!
Your gonna get multiple multiple answers, I've heard read and heard as little as 5hp and as much as 25hp. I personally think most of the hp comes from the milling as the LS7 heads are already CNC ported, but I'm sure there is room for a little improvement.
Bottom line I think if you your gonna do a serious H/C car I would port and mill the heads
I don't have ported stock heads but I do have PRC 265 heads(not milled, so no increase in compression ratio) that flow 9% more on the intake and 12% more on the exhaust.
The shop only adjusted the tune to compensate for the additional flow(otherwise the same tune as stock) and I picked up around 20-25 HP at the rear wheels.
I just got a tune and had my heads ported. The car picked up 30hp and 25tq but I believe most of that was from the tune. I plan on more mods in the future (cam, headers, etc..) which is why I went with ported heads. If you never plan on more mods then I don't think porting is worth it.
Is it just possible to fix the stock heads with new retainers and valve and no porting/milling? I am thinking of doing a mild cam for a daily driver and if I can save 2k from not getting ported heads that would be awesome.
Hey guys,
Thanks!
Thanks!
Absolutely , porting is optional for example with the WCCH stage II rebuilt LS7 heads., you don't need to mill either, they can just resurface so just a little shaving to get a clean start. I stuck with the stock cam and did not mill.
DH
Is it just possible to fix the stock heads with [...] no porting/milling?
Is it just possible to fix the stock heads with new retainers and valve [...] ?
The term "WCCH Stage II" describes a ported head. Best not to use the term "Stage II" if you do not want ported heads (info from WCCH website).
Former Vendor
We have LS7 packages with porting and without porting. Our base Head package is $2308.02 for rebuilding the LS7 heads with all the upgrades(bronze guides, SS exhaust valves, resurfacing, comp valve job, labor, ect.)
Alot of ls7 owners go for our head package without porting and add a cam the same time. That way you get greats gains from the cam and milling but can now sleep at night knowing you have taken care of the LS7 valvetrain issues.
Contact us for a quote today.
Thanks for the replies, the heads are already milled .030 with all the valve guide issues fixed and SS exhaust valves installed from WCCH and has a 228/248 stick. (Put down 557)There will be more mods to come on the car like Fast 102 possibly NW 102 but undecided on the TB, any sugestions? What about the stock fuel pump and injectors? I was thinking the injectors would be maxed out but like I said this is the first Corvette for me.
