C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Oil Pressure Relief valve, oil schematin
Old 08-05-2013, 07:41 PM
rabrooks
rabrooks's Avatar
Default Oil Pressure Relief valve, oil schematic
Can anyone point me to a diagram/schematic that shows the oil flow of the LS7. I am most particularly interested in the oil pressure relief valve and how it works. If you have any info on the oil pump failures, that would be very helpful as well.
FYI, spun the center main. normal driving down interstate
Roger
Old 08-05-2013, 09:01 PM
Mark2009
Mark2009's Avatar
The pressure relief valve is part of the oil pump assy, and is basically a plunger with a spring. I'm not sure exactly where it diverts the excess oil pressure to, but offhand I would think it is pretty foolproof unless it operates routinely (cold starts, what-have-you) and became stuck due to foreign material or some such.
In that case I'd be curious if the PCM is looking at oil pressure in order to trigger an alarm should it be too low (somehow I'm thinking that it doesn't, or at least doesn't until it is ridiculously low -- like 3 PSI).
Old 08-05-2013, 09:06 PM
rabrooks
rabrooks's Avatar
Thanks Mark. I had 8 psi at hot idle with no alarms or warnings. 20 psi at 3500.
Old 08-05-2013, 09:26 PM
KillerFRC
KillerFRC's Avatar
Going through the same issue with my car. #2 main bearing failure with only 23,000 miles.
Old 08-05-2013, 10:26 PM
wstaab
wstaab's Avatar
To Oil Pressure Relief valve, oil schematin
Quick Reply: [Z06] Oil Pressure Relief valve, oil schematin
