C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Help please!Battery volts went down to 12.2 at idle-service charging system
Old 07-27-2013, 01:43 AM
TT32VGT
TT32VGT's Avatar
Default Help please!Battery volts went down to 12.2 at idle-service charging system
Alright so I got my car back from the mechanic(did heads and clutch this time around-had cam, exhaust, fast 102 setup)..
The battery died after 4 days of sitting.. So I replaced it with a duralast gold with a good bit more cca.. I noticed today the battery volts are low.. like as low as 12.2 at idlle.. finally service charging system light came on.. the battery volts at idle at 12.2-13 and driving 13.5-14.. Battery is NEW.. Im thinking alternator, what do you guys think? Tomorrow Im getting autozone to test the alternator..
Help please!
I saw this thread, and started to revive it but as you can see it didnt go in that direction..
http://forums.corvetteforum.com/c6-z...driving-2.html
Old 07-27-2013, 09:28 AM
Mr. Gizmo
Mr. Gizmo's Avatar
Help please!
Alternator is taking a crap. battery was probably going bad for a while, and alternator was working way too much overtime and is petering out.
Old 07-27-2013, 11:39 AM
Landru
Landru's Avatar
Received 1,046 Likes on 820 Posts
Sounds like alternator's going south.
Old 07-27-2013, 12:45 PM
VNAMVET
VNAMVET's Avatar
I have 14.2 showing most of the time. I thought (perhaps wrongly!) that showed that the alternator was charging my battery.
Granted, my battery is 3 years old, and when the vehicle sits for more than 3 -4 days, I notice that the battery has a tough time and turns the engine over slowly. It only takes 3-4 seconds, and fires right up.
Additionally, the door touch pads (just replaced last week) barely open the doors after 3-4 days of non-driving.
Old 07-28-2013, 12:10 AM
2k Cobra
2k Cobra's Avatar
Help please!
Have you used a battery tender??
If your new battery was sold to you in a run down condition, this could happen.
If it was my car, I would put a battery tender on it until it shows full charge, then drive the car. If it still reads low voltage, you could take it to Autozone and have them evaluate the charging system.
Lots of luck, 2k
Old 07-28-2013, 07:26 AM
Landru
Landru's Avatar
Originally Posted by VNAMVET
I have 14.2 showing most of the time. I thought (perhaps wrongly!) that showed that the alternator was charging my battery...Granted, my battery is 3 years old, and when the vehicle sits for more than 3 -4 days, I notice that the battery has a tough time and turns the engine over slowly. It only takes 3-4 seconds, and fires right up.
When my Z has to sit longer than 3-4 days it goes on a battery tender, otherwise my experience is like yours. If you don't use a tender, might consider one.
OP's issue sounded to me like the car wasn't recharging, a good sign of a bad alternator.
Old 07-28-2013, 09:59 AM
Chance575
Chance575's Avatar
you get new tune, if the idle is low and you have a high demand this could be causing the issue
To Help please!Battery volts went down to 12.2 at idle-service charging system
Quick Reply: [Z06] Help please!Battery volts went down to 12.2 at idle-service charging system
