C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Headlight Failure
Old 06-18-2013, 11:17 AM
Drew182
Cruising
Drew182's Avatar
Default Headlight Failure
My passenger headlight is not working properly,
It flickers for a bit then goes out.. sometime it will stay on for a few seconds then flicker again and go out.
My guess is the ballast.
Any ideas? I live in canada and the dealer wants $600 for a new one!
There is a nice vocal section in the video from my employee.. enjoy
Old 06-18-2013, 11:46 AM
GMuffley
GMuffley's Avatar
Check to see if the relay is loose.
Old 06-18-2013, 01:12 PM
Drew182
Cruising
Drew182's Avatar
relay is tight, I also tried a new one with no success.
Old 06-18-2013, 01:14 PM
Boosted Josh
Boosted Josh's Avatar
Can you swap the bulbs from side to side to at least remove that variable?
Old 06-18-2013, 01:51 PM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
There is an NHTSA investigation on headlamp failure but it's usually on both.
http://www.corvetteblogger.com/2013/...te-headlights/
__________________
Contact:
(e) zach@katechengines.com
Old 06-19-2013, 03:30 PM
Drew182
Cruising
Drew182's Avatar
I switched bulbs from side to side and the problem stays with the passenger side..
I guess i need to go buy a ballast, and pull the front bumper off to change it.
What a pain!
To Headlight Failure
Quick Reply: [Z06] Headlight Failure
