[Z06] One piece brake pads for street that don't require clip...
I am using Hawk DTC-70 for the track with DBA rotors. I do about 6 HPDE a year. Changing out these padlets is getting old. I have bent these retainer clips more times than I can count.
Are there any one piece street pads I can use that don't require the clip?? Or is that clip necessary for all street pads. I would like to keep stock rotors for the street for appearance.
MC
MC
Ummm....what one piece pads are you using? Pretty sure the one piece Hawk's I just installed required the anti-rattle clips. Have yet to see a one piece pad (or any pad for that matter) that don't require the anti-rattle clip.
Received 8,926 Likes
Depends on what brand you purchase. It is impossible to use the pad retaining clips if you use the Cobalt one piece pad. Hawk and Carbotech one piece pads require the springs and are notched for the springs. That can make them almost as much of a PIA to install as the padlets since they can still get hung up on the edge of the spring as you try and push them in.
Bill
Bill
Even with other pads that are cut so they can accept the "anti-rattle" clip, I don't see why there would be a problem if it wasn't used, the pad would just possibly rattle around a little. While not necessary to use all the retaining pins with the single pads, I still do.
Why would you think the pad would destroy itself if there was no anti-rattle clip? It is there to keep the pad from rattling, not to retract it or locate it.
Anti rattle put another way means anti-vibration. The amount of heat the brakes deal with is extreme. Adding vibration into the mix would cause hot spots during initial bite, and excessive wear...if not all out failure during something like a HPDE where your brakes are being beat on. Maybe its do-able in an all out race pad because they're designed to be replaced after a few hours of use...not 50K miles like a street pad needs to be. Plus, the vibration would (or should) cause squealing on a unbearable level. IMO anyways.
As I told Bill...the fact that a company makes a "street" pad that doesn't use a rattle clip is intriguing to me...and worth researching into how they market it.
Opinions may differ.
The other thing to think about is if you want to run the Hard Brake titanium heat shields. They have to be used with one piece pads and no anti rattle clips as they have no cutouts for the clips. I tried using them with a set of padlets and the clips and they got hung up on the clips. Had a spongy brake pedal until I removed them.
Bill
Bill
I run the DTC 70 on front and DTC 60 on the rear. No clips at all. They fit properly and don't squeal. Talk to Ken at KNS. He is in teh classifieds alot.
Damn, learn something new every day.
Supporting Vendor
St. Jude Donor '11,'13
MC
MC
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
I spoke to Ken at KNS and without opening a bunch of brake pad boxes, this is what he remembers. The hawks and Carbo tech don't require clips. Stop tech and Cobalt do. I can only be sure about the Hawk single DTC's they don't require clips. Its only for noise anyway. Mine will make a little squeal at very low speeds (moving around the paddock speed) and its only once in a while. I asked Ken why some set ups squealed more than others of the same brand pads. He said that the pads must be properly bedded in. And if so, they are less likely to squeal. So if your trying to put new pads on old rotors or your rotors are not de-oiled before bed in, you could have a speal problem.
Cheer
Cheer
Cheer
Cheer
My Carbotech street pads and track pads both can use the clips and I have.
I run the one piece Hawks...with clips. No noise at all...ever.
I run the DTC-70 at the track without the clips and notice no significant noise. I had originally planned to re use the clips but the things are too warped. I know I have to remove the caliper with one piece pads but not dealing with the pins and clips is worth it to me.
MC
MC
MC
MC
Bill
Stoptech pads in my stock calipers and I'm not running the clips. I worked them in there but then asked the dealer I got them from and he told me they're not designed to run with the clips.
