[Z06] Every Tech should have this LS Timing cover Alignment Tool!
Supporting Vendor
AlignIt Tools are used to align the Rear Main and Timing Covers and install the seals!
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-LQ9- 5.3-6.0 and all GM v8's from 1997-2013 Timing and Rear Main cover and seals. Works with all LS based engines!
Here is a couple simple but very effective tools to help you make easy work of aligning your Timing and Rear Main Covers. CNC Machined to exact tolerances, the AlignIt tools
get the covers centered perfectly with the crank. The O-ring design makes for a perfect snug fit no matter the temperature that can cause expansion/contraction of engine covers, crank & tools
that will hinder a perfect fit. The O ring design eliminates this problem. After the covers are centered and torqued down, use the AlignIt Tools to install the seals in seconds!
Available in the Pro Series 6061 Aluminum Anodized and the standard PVC Plastic. Both are CNC Machined to exact specs from Billet materials.
www.saccitycorvette.com/AlignItTools.html
If you're doing a Rear Main Seal or Engine Build, its a good time to start keeping unfiltered oil out of your bearings and lifters! Check these Billet Oil System Improvement parts out!
https://www.saccitycorvette.com/OilS...provement.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Mine arrived today. Can it be used with the oil pan on? The one I got has an o-ring on one end. Does that go towards the oil pump or away from it? The one in the video doesn't have an o-ring.
Supporting Vendor
You have the latest tool with the Oring. The Oring goings toward the engine into the cover.
Christian
Supporting Vendor
The Hub Simulator Tool is for those that do not want to remove the seal.
It simulates using your hub to align the timing cover with the seal in place.
Supporting Vendor
It sounds like you went to the school of hard knocks.
Supporting Vendor
i want all 3?...Paypal?
Supporting Vendor
Hi blown81bu,
Here is the link. PayPal works!
http://www.saccitycorvette.com/Timin...nmenttool.html
Thank you,
Christian
Thank you,
Christian
Just ordered 4 sets on their way to New Zealand tomorrow i think , I did make one for the front seal out of an old pulley but cant be bothered making a rear one for what these cost , mind you our dollar only 71 cents, but still good value so will distribute the other 3 sets to other engine guys , thanks
Supporting Vendor
Yes they are on the way.
Thank you for your business.
Norma
