C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] C6 Z06 tapping engine noise
Old 05-19-2013, 03:29 PM
camirocz
camirocz's Avatar
Oui je parle le francais ma mere est de France et je suis ne a Montreal.Ton moteur cogne du bas ca c est sur.Cest un cognement et non un claquement.C est tres evident en ecoutant ton video.
Old 05-19-2013, 03:42 PM
Arjian
Arjian's Avatar
How can I check my lifters ?
Old 05-19-2013, 03:45 PM
Arjian
Arjian's Avatar
Donc tu penses que ça viens d'un roulement de vilebrequin !? D'un coup comme ça ?
Car c'est arrivé le jour où j'ai rajouté de l'huile. Je roulais tranquillement quand le bruit est apparu.
Old 05-19-2013, 03:46 PM
erikszr1
erikszr1's Avatar
hows the oil pressure? it doesn't sound good. sounds like a rod bearing to me. I hope not.
Old 05-19-2013, 03:47 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
I see I'm not the only one sho thinks it might be bottom end. I hope I'm wrong but it sounds that way to me.
Old 05-19-2013, 03:50 PM
erikszr1
erikszr1's Avatar
Originally Posted by ramairws6
I'm sorry to be a Debbie downer but that sounds like a rod or main bearing then a lifter for sure.....
Old 05-19-2013, 03:52 PM
Arjian
Arjian's Avatar
The oil pressure i normal, 350kpa when cold at idle and 50kpa at idle when fully warmed up
Old 05-19-2013, 04:00 PM
z0sicktanner
z0sicktanner's Avatar
Oh boy, thats not good. Sounds like a rod or main bearing from that video. So hard to tell over the intrawebs though...
dont drive or run the car op...get that looked at asap
Old 05-19-2013, 04:06 PM
chris2000
chris2000's Avatar
I agree also. I wouldn`t drive this car. Get it checked and save the engine!
Old 05-19-2013, 04:08 PM
Arjian
Arjian's Avatar
Yes but to test it with the unplugged spark plugs I have to start it !?
What do you mean when you say "ASAP" ?
I would to do it myself, it don't scared me ! I always repare my cars myself.
Old 05-19-2013, 04:10 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
ASAP means....as soon as possible
Old 05-19-2013, 04:23 PM
Arjian
Arjian's Avatar
ok thanks
What should I do yet ? inspecting the oil and filter or Pull the intake manifold to check the lifters ?
Old 05-19-2013, 05:06 PM
  #33
chris2000
chris2000's Avatar
you should check everthing to solve the problem :o)) wish you luck!
Old 05-19-2013, 05:13 PM
  #34
Turbosixx
Turbosixx's Avatar
Pull the intake and heads, remove lifters. If that's not the issue, pull the engine out.
Old 05-19-2013, 05:22 PM
  #35
z06 driver
z06 driver's Avatar
Adding oil at the same time the noise started is a coinsedence, don't dwell on that you have a serious problem.
Old 05-19-2013, 06:58 PM
  #36
LT5 John
LT5 John's Avatar
That sure sounds like a bad bearing to me, from the sound of your video...
Old 05-19-2013, 07:43 PM
  #37
MGP1
MGP1's Avatar
2020 C6 of the Year Finalist - Modified
don't run it!
To C6 Z06 tapping engine noise
Old 05-19-2013, 08:15 PM
  #38
JJC5
JJC5's Avatar
You said that you added oil and that's when it started making the knock sound. Where did you add the oil? Did you add it to the oil tank or did you put it in through the valve cover? If you added it through the valve cover, it may have hydro locked one or more cylinders that can easily bend the connecting rods. Did it turn over freely after adding the oil? Did it smoke out the exhaust? That knock sounds like like the bottom end for sure. That's not a lifter.
Good luck!
Old 05-19-2013, 08:22 PM
  #39
Arjian
Arjian's Avatar
I don't can pull the engine out ! I will check the lifters tomorrow. But anyone can tell me how can I control those lifters please ?
But what I'm don't understand, is that when the engine i dead gold, it makes no noise what so ever.
If a rod bearing is broken or got some play, it would make the noise immediately isn't ?
Old 05-19-2013, 08:31 PM
  #40
Arjian
Arjian's Avatar
I add some oil true the oil tank for sure ! I had previously checked the procedure on youtube.
It started to knock for about 20minutes later to the oil adding when I was driving it
No smoke on the exhaust what so ever.
Quick Reply: [Z06] C6 Z06 tapping engine noise
