C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Diff and Transmission fluids
Old 05-13-2013, 02:01 PM
NW94Z
NW94Z's Avatar
Default Diff and Transmission fluids
Looking to replace these fluids in the next month or two and I was wondering if I should just go with the GM over the counter fluids or are the aftermarket fluids better here like they are for engine oil? The DIY sticky for the Diff fluid change gives me the impression that the GM fluid is acceptable.
My only concern with the diff fluid is the GM LSD additive that comes premixed with the current GM sold fluid. Do I need to add the additive separately if I use a non GM brand like Redline?
Old 05-13-2013, 03:42 PM
TKOGTO
TKOGTO's Avatar
Contact Brad Neff (Subdriver here on the forum). He sells Amsoil products and is an excellent source of information about your issues and most everything else Corvette related. Good guy too.
Old 05-13-2013, 03:59 PM
Mookster
Mookster's Avatar
RichieRich recommended Amsoil for diff and tranny fluid, anyone try it?
This diff fluid
http://www.amsoil.com/shop/by-produc...e-gear-75w-90/
LSD additive
http://www.amsoil.com/shop/by-produc...-oil-additive/
and this tranny fluid
http://www.amsoil.com/shop/by-produc...mission-fluid/
Its noticeably more than GM fluids but if its worth i might as well get it? Anyone?
Old 05-13-2013, 07:53 PM
NW94Z
NW94Z's Avatar
This diff fluid
LSD additive
Looks like the Amsoil Diff fluid includes the friction modifier but it's recommended to add another 4oz to be sure. Apparently the Z06 diff requires a lot of the FM to eliminate chatter.
Old 05-14-2013, 07:18 AM
GOLD72
GOLD72's Avatar
Received 1,101 Likes on 715 Posts
AMSOIL fluids in my cars for the past 5 or 6 years now.
Old 05-14-2013, 07:22 AM
capevettes
Support Corvetteforum!
capevettes's Avatar
Received 4,540 Likes on 2,156 Posts
2016 C2 of Year
2015 C3 of Year Finalist
I did the rear diff and tranny fluid changes recently to my 06 Z06 and used the GM fluids recommended in the DIY. The GM rear diff fluid has the friction modifier in it. You do not add the posi lube to it. It quieted down my rear end which was making a little noise when cold backing out of the garage. I also used the GM tranny fluid which helped a bit with the cold notchiness when shifting but did not completely eliminate it.
Old 05-19-2013, 08:49 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
Thanks for the mention and sorry missed this thread this week.
Concur with the options listed above. The tranny and diff fluids are the same I use in my 02 Z06 at the track. However, the C6 diff clutch plates are made out of different material than the C5 diff clutch plates and need more additive. While the Severe Gear comes with friction modifier already in it, extra is usually needed for the C6 diff to prevent diff chatter.
More than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
P.S. Note the forum name change and sorry for the confusion. Changed the name to more closely align with most of my posts these days which are related to my racing/business.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 05-19-2013, 12:46 PM
ZR-1 1991
ZR-1 1991's Avatar
Which fluid did you use ? My GM dealer tells me Dexron VI
But the owners manual says to use (p/n 88861800 for GM fluid)Manual Transmission Fluid .Which is correct ? I checked a 2013 owners manual is says to use Manual Transmission Fluid .
Old 05-19-2013, 12:50 PM
SergeantZ
SergeantZ's Avatar
I changed my engine oil/filter, trans, and diff fluid over to AMSOIL last year. For the diff I used the severe gear + GM additive, however my diff still chatters like crazy in parking lots. I'm about to change it out again with the newer GM formula that includes the additive to see if there's a change.
Old 05-19-2013, 03:10 PM
ss2z06
ss2z06's Avatar
It is a different fluid for the manuals. Your dealer is wrong. They are probably similar but get the manual fluid.
Old 05-19-2013, 03:26 PM
K.Shupe
K.Shupe's Avatar
St. Jude Contributor
I've used these AMSOIL products in both my Z06 and ZR1 with excellent results.
AMSOIL Severe Gear 75W-90
AMSOIL Slip Lock Gear Oil Additive
AMSOIL Torque-Drive
Brad (C66 Racing) will take care of you, nice guy, GREAT service!
Just a note on my experience with the friction modifier additive. As has already been said the AMSOIL Severe Gear comes with friction modifier already added and too much can effect how well your limited slip will work. So the first time I used it (on the Z06) I only added 2oz, worked great, no issues. When I did the diff fluid change on my ZR1 I reduced the amount of additive to 1oz(easy enough to add more if necessary) and again no issues. Your milage may vary.......
Old 05-19-2013, 08:44 PM
Mark2009
Mark2009's Avatar
Stay away from that dealer. He is going to break your car.
Originally Posted by Bill Dearborn on 3-26-2011
The part number is a GM Part Number for Dexron III.
I found this on the web for what it is worth:
Per GM service news
This information applies to 2007 and prior GM passenger cars and trucks.
Dexron III is being phased out as a product name. It is being renamed Manual Transmission Fluid and carries p/n 88861800 U.S. (88861801 Canada).
If fluid p/n 88861800 U.S. (88861801 Canada) is not yet available when servicing a manual transmission or transfer case, Dexron III can be used in its place.
DO NOT use Dexron VI in place of manual transmission fluid in any manual transmissions or transfer cases that specify Dexron III, as a failure may result.
Bill
Old 05-19-2013, 09:13 PM
ToppThat
ToppThat's Avatar
St. Jude Donor '12
I used Royal Syncromax#01512 in the trans.4qts min. In the diff.i used 2-3 qts.R.P.Max Gear#01300 75W90 It said it had limited slip additive in it,i used a additive anyway and im very happy since i left stock hp behind long ago.Be sure to get your cooler line clips from dealer first(another rip off) And a lift is VERY helpful.Good Luck.
Old 05-20-2013, 07:45 PM
C66 Racing
C66 Racing's Avatar
Adding to those indicating your dealer is wrong...
You want 88861800 if you are going to use a GM fluid. The Dexron VI viscosity is about 25% lower than that of the original GM Dexron III spec which was the original GM spec for the Tremec manuals in GM applications.
Old 05-21-2013, 07:33 AM
GOLD72
GOLD72's Avatar
Which fluid did you use ? My GM dealer tells me Dexron VI.................................
Your dealer is a knothead for stating DEX 6 for a Tremec manual tranny.
To Diff and Transmission fluids
Quick Reply: [Z06] Diff and Transmission fluids
