C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Stock C6 Z06 Dyno numbers?
Old 05-11-2013, 08:40 PM
VictoryRedZ06
VictoryRedZ06's Avatar
Default Stock C6 Z06 Dyno numbers?
Today I put down 436.3 HP and 403.3 ft-lb torque zero mods....what did you guys get?
Old 05-11-2013, 08:49 PM
C6DuffMan
C6DuffMan's Avatar
No mods.
Old 05-11-2013, 08:56 PM
VictoryRedZ06
Originally Posted by C6DuffMan
No mods.
Thanks for sharing C6DuffMan! Nice numbers too! Fully stock? No tune? What mods do you have now? Numbers? Thanks again
Old 05-11-2013, 09:13 PM
ClarksZ06
ClarksZ06's Avatar
My bone stock numbers were 445/428 on a dyno jet
Old 05-11-2013, 09:15 PM
LS9Drew
LS9Drew's Avatar
431/415 all stock but the first gen Halltech KB1
Old 05-11-2013, 09:26 PM
VictoryRedZ06
Nice! Thanks for sharing ClarksZ06
Old 05-11-2013, 09:28 PM
VictoryRedZ06
Alright bro! We're real close then...I guess that's the norm 430-450rwhp in that range huh?
Old 05-11-2013, 09:32 PM
LS9Drew
LS9Drew's Avatar
Depends on the dyno, but ya that seems to be the main range. Most other dynos around usually get 450ish
Old 05-11-2013, 10:53 PM
Mark2009
Mark2009's Avatar
Depends on the dyno [...]
OP, when posting dyno figures it is best to state the brand of dyno as well as the correction factor used. Otherwise comparisons won't mean much.
DynoJets seem to give the highest numbers.
Old 05-11-2013, 11:48 PM
VictoryRedZ06
Thanks Mark200X not sure, it was on a ramp though up, not on the ground
Old 05-12-2013, 07:45 PM
propain
propain's Avatar
St. Jude Donor '14
Old 05-12-2013, 08:40 PM
Mark2009
Mark2009's Avatar
If that's stock somebody had their finger on the scale
Old 05-12-2013, 08:53 PM
JT Metal
JT Metal's Avatar
St. Jude Donor '12-'13
Does 403torque seem low?
Old 05-12-2013, 10:19 PM
Mark2009
Mark2009's Avatar
No.
Keep in mind that the dyno does not measure horsepower; it measures (or calculates) torque then calculates horsepower from that measurement (calculation). HP = TQ * RPM / 5252
403 torque might be just a smidgen low for a Dynojet, but the OP doesn't know what kind of dyno was used. For a properly set up load cell dyno (like a Mustang or a DynoMite) the numbers he got would probably be in line with 440-450 HP on a Dynojet (inertia dyno). Based on ballpark numbers and various comments from various operators and such.
Or if the run was made on a Dynojet the IAT could have been a tad high or some timing might have been pulled up top if the cats were running hot. I think coolant temp might play into the mix as well. 93 octane in the car, or 91? All kind of variables, so pretty much impossible to make any judgement without a lot more info and a data log. Given all that, it looks like a good number to me -- I'd be happy with it
Old 05-12-2013, 11:24 PM
VictoryRedZ06
Hey Mark on the dyno sheet it says DYNOmite so what's that mean? Thanks again
No.
Old 05-12-2013, 11:25 PM
VictoryRedZ06
Originally Posted by propain
Nice
Old 05-12-2013, 11:31 PM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,546 Likes on 2,620 Posts
My '09 stock with just a ZR1 air filter element was 469.38rwhp and 437.9 torque (corrected) on a Dynojet Research dyno (at Extreme Motorsports), but they know the numbers using SAE5 smoothing are generally 455 to 475 for LS7 stock on their dyno, so mine is good but now as great as it may seem compared with some other dyno's.
To Stock C6 Z06 Dyno numbers?
Old 05-13-2013, 08:57 AM
Mark2009
Mark2009's Avatar
Ah! That means it is a load cell dyno, which probably means it reads a little lower than the Dynojets (inertial dynos) that everybody loves because they usually give higher numbers
I'd say that your numbers on a DYNOmite are pretty good and well within what other Z06's would do on the same dyno.
On the lower left corner of your sheet it probably says "Correction factor: SAE".
My bone stock '09 Z06 with 49K miles on the original air filter pulled 400 TQ on a DYNOmite. HP curve was a little flattened out on top at 424 HP, looked like the PCM pulled a little timing due to cat temp (or so the operator said) (2nd pull). So, you and I are right in the same ballpark on that type of dyno.
11.5 AFR on my pull, according to the tailpipe sniffer.
Old 05-13-2013, 09:26 AM
yellowzron
Banned Scam/Spammer
yellowzron's Avatar
My 2007 with 4500 miles on it put down 456 on a Dynojet.
I thought it was high but I will take it.
It was bone stock, no mods at all. Then I did a cai/KN with a tune ant it went to 487.
Old 05-13-2013, 09:29 AM
VictoryRedZ06
Whooo! Yes it does say *Correction Method: SAE in the bottom left hand corner. I guess I'm right in line with other Z06's I've been trying to post the pic of my dyno sheet but can't figure it out. Thanks again Mark!
Quick Reply: [Z06] Stock C6 Z06 Dyno numbers?
