C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] C6 z06 ,,,clutch problem shifting
Old 05-09-2013, 09:35 AM
KING_PIN6
KING_PIN6's Avatar
Default C6 z06 ,,,clutch problem shifting
i drive c6 z06 49600miles ( stock ) with stock clutch..
i have been noticed that at start up and with car in NEUTRAL .. WHEN I PRESS THE CLUTCH I CANT SHIFT TO ANY GEAR AND I HAVE TO PRESS CLUTCH TWICE OR MORE JUST TO GET INTO ONE OF THE GEARS ..BUT I DONT HAVE ANY ISSUE WITH SHIFTING AT DRIVING ..
AND I ALREADY DID RANGER METHOD BECAUSE THE CLUTCH FLUID WAS REALLY DIRTY...
I WANT TO FIX THIS ISSUE ..
AM I HAVING PROBLEM WITH SLAVE CYLINDER?????????
Old 05-10-2013, 06:20 AM
KING_PIN6
KING_PIN6's Avatar
NO REPLY
Old 05-10-2013, 11:38 AM
Fifedogg
Fifedogg's Avatar
You should try bleeding the system. This can be done with a Mighty Vac through the Master Cylinder. Not sure but worth a try.
Old 05-10-2013, 11:51 AM
KING_PIN6
KING_PIN6's Avatar
i already bleed the system on december 2012
and i did ranger method yesterday.
and today i drove the car and i didnt face any problem
..most of them told change the clutch because you have problem with lack of engagment of the clutch and other said slave cylinder.
To C6 z06 ,,,clutch problem shifting
Quick Reply: [Z06] C6 z06 ,,,clutch problem shifting
