[Z06] 24k Track Miles Wiggle Test Video
I posted up guide spec sheets for this a month or so ago. After 24k tracked miles and a dropped exhaust valve these heads show no signs of valve guide wear. These are the heads that were sent to me by
505z06. In the video you will see I compare the wear on this head to another dropped valve z06 head that I have here with significant wiggle room. as you can see with the loose guides there is no way to transfer heat when the guides are out of spec. this heads has No wear an still dropped a valve.
I'll have to look through them.
Interesting video though.
You can see the damage to that head, but there are people in here right now whose guides are not in that good of shape.
http://forums.corvetteforum.com/c6-z...post1583357326
Last edited by '06 Quicksilver Z06; 05-05-2013 at 07:34 PM. Reason: Found the guide spec sheet
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
I am not the slightest surprised that you and Quick were the only ones to post in here before I did.
It is because most people on here have heard you and the usual suspects beat the living chit out of this issue and when we see that you started yet another thread, it makes us want to beat our heads on a table.
Supporting Vendor
St. Jude Donor '08
well I've had 5 ppl call me to day Rich from this forum. how those ss valves and bronze guides working out for ya?...see i post up real info unlike most ppl on here. funny to that you put new valves in one guys head then put used valves in les heads. again I ask you was I wrong 3 years ago? seems to me I started the wiggle test on this forum. you seem to be getting alot of work from that...lol whats really funny to me is you run the same valves and guides as me. what was you worried about? you didn't want to lose another engine did you? so trust me I think it's really funny
My engine, heads and every other aspect of my car is great. I have no complaints at all. We can continue to race it, beat on it and enjoy the power it makes.
I work for a franchised GM dealer that is required to follow certain policies and procedures. GM warranty dictates what we can and can't do. If the valve stems measure out OK, then they have to be reused. If they are worn, pitted, or damaged in any way then they get replaced. So far, the vast majority of them are OK. I think that is mainly because the cars that we are seeing under warranty are low miles and not abused.
Considering the very low number of failures that we've seen here, compared to very high number of Corvettes that we service, I am not part of the tin foil hat crew that you belong to. 3 stock LS7 failures related to exh valves in the last 7 years is not a bad track record regardless of what you may think.
I'm glad that you find amusement in what I do.
I'm trying to make out what you're attempting to type in here, but it is difficult so hopefully I will answer OK.
Supporting Vendor
St. Jude Donor '08
and those cars with .0080 plus guides wear would have failed just like yours did. when you have guide wear the valve is gonna have stress marks galling from a loose guide. anyone that knows anything about heads will tell you that. the numbers go up daily so the tin hat crew you call me is priceless when you yourself run the same parts as me. so it's more than amusement for me. can't bite the hand that feeds you huh? I don't have that problem I work for myself so I tell the truth when it comes to these heads.
That's what is funny about you and the other tin foil hat guys.... You think that a car with .005" guide wear is a ticking time bomb and you will go out of your way to try and make everyone else believe the same.
You can't say that a car with .008 guide wear is about to fail. I've had older out of warranty LS7 cars in here with .013"+ wear that just came off a track day the weekend before. One in particular had 30+ track days and guide wear that was above .011" on all cyls, with the highest being .014". Car was running great and had 80k miles on it. No noise, no smoke, no signs of the engine about to fail.
But will they fail eventually given that they are out of spec? I agree not all will fail at any given point being out of spec. I disagree that they wont fail eventually from being out of spec. Its a matter of use and abuse that will either extend or shorten the amount of time.
I know all cars fail eventually but when the LS7 lets go it seems to always be at this fail point and its a catastrophic failure.
I also find it funny that GM's spec for the clearance is the same for virtually all their V8s, without regard for HP or valve material.
^^^^Lot of Bloviation above and more to come^^^^^^^^^^
It would be interesting to do the wriggle test on LS motors not LS7. as far as that goes on ford motors, and even going back to L98's put in corvettes and pick up trucks pre-1992. I bet most of them if not all wriggle.
