C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] LG long tube headers vibration
Old 05-05-2013, 03:22 PM
boricua1950
boricua1950's Avatar
Default LG long tube headers vibration
I installed new LG long tubes headers with cats and X pipe in my 2010 ZO6, now the passenger header is vibrating agains the frame. I looked and everything looks ok and tied. The driver side don't touch anywhere. By the way the installation was done by a high performance shop and they dyno it after they finished. Need help, thanks.
Old 05-05-2013, 03:39 PM
mistermog
mistermog's Avatar
I had all sorts of problems with mine... the order you tighten the bolts seems to matter. I know that doesn't really help since a shop did it, but i'd bring it back to them and ask them to refit it.
took my 3 times with my kooks before things fit decently.
Old 05-05-2013, 04:18 PM
boricua1950
Thanks, I will.
Old 05-05-2013, 06:52 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
With the motor hot, place a tire iron between the header and the frame. Give it a gentle pry. You'll get your 1/8" and will be fine.
Old 05-06-2013, 08:30 AM
WhiteDiamond
WhiteDiamond's Avatar
St. Jude Donor '15
If you cannot get the added clearance by having the shop check the bolts, then a little dent in the offending primary is the best solution.
To LG long tube headers vibration
Quick Reply: [Z06] LG long tube headers vibration
