[Z06] Weird fob question
Weird fob question
Both of the fobs I have for my car will start and lock/unlock the car. The odd thing is this, one works perfectly fine and the other one whenever I used it always makes the side view mirrors go all the way down. I have no clue why it is doing it and I just want it to go away!
The FOBs are marked 1 and 2. They are matched to the memory 1 and 2. Look for the number on the FOB that is causing the mirrors to point down, push the same number memory (probably 2, if you usually use 1), the mirrors should go down just like with the FOB, set the mirrors how you like, press and hold the memory button to memorize the new setting.
You can also set: heating/AC, radio station, steering wheel position (fore and aft), etc. It is all spelled out in the OWNER'S MANUAL.
Jim
Jim
