[ZR1] tick Master install???
I got 2011 ZR1, installing a tick master and a tilton slave. Does clutch pedal need to be drilled on 2011. it seems to put an angle on the levar. Does anyone Know the reason? It seems better to be done with factory pivot point. Any Help..
Yes you need to drill a hole in the stock clutch pedal.
The Tick/Tilton spherical fitting does not fit the stock pin.
You need to use the pivot pin supplied with the kit and follow the instructions.
Well we just checked the size and it fits perfect. I was thinking maybe it was moved for more leverage due to stiffer unit. The angle on the shaft is actually straighter on original location. I think I'm going to try it there.
