C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 427 question, not sure where else to post
Old 05-06-2013, 06:43 AM
doglegdd
doglegdd's Avatar
Default 427 question, not sure where else to post
I need your help!
My 2013 427 was recently supercharged with the edelbrock SC. Everything ran great and never had a check engine light on for 2500 miles. That is until recently, lately from time to time my engine light will come on and my dash will show a "service traction control system". During this time the car is running rough and feels like its misfiring.
It will do this until I turn it off. Sometimes 5 minutes or hours between re-starting it is required to get the car to run right but when it is running right it is like nothing was ever wrong.
Has anyone seen this?
Old 05-06-2013, 08:34 AM
Wulverine
Wulverine's Avatar
St. Jude Donor '15
I would check your plugs and plug wires.
Old 05-06-2013, 08:37 AM
doglegdd
doglegdd's Avatar
I'll do that, but if it was plugs / wires wouldn't it be running rough all the time? Most of the time it runs like a beast, only at times when the message pops up does it run rough.
At anyrate, its a great place to start, thanks.
Old 05-06-2013, 08:47 AM
JwT
JwT's Avatar
First of all let me say it must be nice to have a new vert. I don't understand the S/C with a 11.1 compression ratio but what the heck. Its hard to determine if the wires are bad just by looking at them. There pretty fragile and even a cracked ceramic sheath on the inside can cause a misfire. Time to have a mech look at the car....hey...you can afford it.
Old 05-06-2013, 08:54 AM
Mark2009
Mark2009's Avatar
Check for any stored codes. If you don't have a code reader, major chains like Autozone will check for you.
Or take it to the shop that did the install.
If the codes indicate a misfire on a particular plug, make sure that plug boot is fully seated.
Old 05-06-2013, 08:55 AM
doglegdd
doglegdd's Avatar
Thanks.
I am a torque junkie. This is not my first vette or convertible. I sold a 2010 twin turbo GS to get this one. I love the 427 but as always I need more pull, I guess its a sickness. I'm only pushing 5lbs of boost and I dont have any plans to push more boost, although I will add headers, head work and a cam this next winter.
Yes, I't be at the service department this week. I hope it is something as simple as plugs / wires.
Old 05-06-2013, 08:56 AM
FSTFRC
FSTFRC's Avatar
Might want to post this in the Forced Induction section too, there is a lot knowledge in that section about this supper charger
Old 05-06-2013, 08:57 AM
doglegdd
doglegdd's Avatar
Thanks, I thought there might be a better place but I did not know where.
Old 05-06-2013, 09:06 AM
doglegdd
doglegdd's Avatar
If the codes indicate a misfire an a particular plug, make sure that plug boot is fully seated.
I would love to take it to the shop that did the install. Those guys are great but they are in Alabama and I am in NE PA. I'm just going to drop it off at the dealership and listen to them figure ways out to rip me off due to the supercharger.
Old 05-06-2013, 09:18 AM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Is there a local shop you can take it to?
One that might be willing to work with the shop in Alabama to help you with this matter.
I would be real leery of taking it to a dealership.
Isn't ECS in that neck of the woods?
Old 05-06-2013, 09:20 AM
doglegdd
doglegdd's Avatar
I moved my post to forced induction. If anyone wants to help here please do, I will keep an eye out and thanks.
http://forums.corvetteforum.com/c6-f...post1583826082
Old 05-06-2013, 09:23 AM
jedblanks
jedblanks's Avatar
It is probably not an install issue if it ran great for 2500 miles.
I would search for other reasons the Service Traction Control comes on.
I supposed a plug could have backed out, or a wire cracked.
More than likely it is an unrelated issue. A speed sensor can cause this. Wrong size/mismatched tires can cause this. Stainless steel brake lines can cause the sensor to act funny. Bad ground...etc etc.
The codes will lead you towards the issue.
doglegdd
doglegdd's Avatar
They are. Thanks, I did not think of them. I'll see if they would be willing to help me out. I agree with you about the dealership. They could easily screw up things worst and or rape me in troubleshooting charges.
Old 05-06-2013, 09:26 AM
doglegdd
doglegdd's Avatar
I hope your right. Like I said, 95% of the time its running like a beast with no issues and then,,,,,Bam the warning comes on and it goes to rough running. Very strange and frustrating.
The only mod at this point is the SC. I planned on more this winter but I'm just trying to enjoy it as is for now.
Old 05-06-2013, 10:08 AM
Landru
Landru's Avatar
Received 1,047 Likes on 821 Posts
Since you report 'rough running' have the MAF checked.
IIRC rough running's a symptom of bad or ill-fitted MAF.
Old 05-06-2013, 10:12 AM
doglegdd
doglegdd's Avatar
Is that something a owner without mechanical skills can check?
Old 05-06-2013, 10:38 AM
Landru
Landru's Avatar
Might, be looking for loose connections and/or oil build-up. From what I've read over the years concerning MAFs, they're pretty delicate so it doesn't take much to cause one to act-up resulting in lousy (rough) performance.
OTOH if it IS a 'failing/bad' MAF, probably need expert's guidance as I do not know what diagnostic are invloved.
To 427 question, not sure where else to post
Old 05-06-2013, 10:41 AM
doglegdd
doglegdd's Avatar
Thanks. I'll be careful but in the mean time, I am trying to line up ECS to see if they can look at it and maybe throw on some headers and retune.
Old 05-06-2013, 11:07 AM
Wulverine
Wulverine's Avatar
St. Jude Donor '15
That's your best course of action without a doubt. ECS will take care of you.
Old 05-06-2013, 11:08 AM
Landru
Landru's Avatar
...in the mean time, I am trying to line up ECS to see if they can look at it and maybe throw on some headers and retune.
Perfect people, and time to check a MAF.
Quick Reply: [Z06] 427 question, not sure where else to post
