C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Another Z engine bit the dust yesterday
Old 05-02-2013, 04:50 PM
  #361
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Originally Posted by Cantevendrive75
My motor had 26,000 street miles on it + 15 track hours. Prior to any track hours... the rocker arms were upgraded and increased capacity lingefelter tank installed. While tracking it... oils were changed twice as often as recommended and the motor short shifted at 6500RPM.
I did everything but the replace the exhaust valves because I was unaware of the problem when I had the motor done. Had I known and/or had the shop told me about the possibility of a $20K catostrophic engine failure due to a $50 exhaust valve... I would have had the work done and my final bill would have been $18K instead of $16K and I would "likely" not be looking at replacing it with a $20K motor right now. So... $18K total cost to do it right the first time instead of the $36K I am looking at today.
Knowing what I know today (which isnt everything) my recommendation is to seriously consider replacing/rebuilding/inspecting your LS7 heads prior to track use. If your motor is out and apart anyway... it becomes a no brainer in my mind.
KV
Wow. what a tough break.
It's examples like this one which make the decision easy for many in here and ends a lot of the arguing.
Was this the one with the GT19 Lingenfelter package in it?
If so, how long had you been running it?
Old 05-02-2013, 06:34 PM
  #362
Cantevendrive75
Cantevendrive75's Avatar
Ya... I got a "partial" GT19 Lingenfelter package put in/on the engine. The reason I say "partial" is that even though the work was done by an authorized Lingenfelter dealer... the heads never came off the engine. Having said that... I dont know if they would have replaced the exhaust valves as part of their "complete" GT19 package or not... so not wanting to slam Lingenfelter either directly or indirectly... I want to throw that disclaimer out there.
All I know is after I blew the engine I talked to the Lingenfelter dealer that did the work and the company rep said they/he knew of a failure rate on the exhaust valves but it was so small (1 or 2%) that they dont/didnt mention it to their clients. I wish he had told me as I told him I wanted to fix "any weak links" in the motor and I had a reasonable budget to work with. Just goes to show ya... you can ask all the good questions ya want... doesnt guarantee good answers or advise. I think the exhaust valve failure rate is low for street driven LS7's... but I personally believe it is unacceptably high for LS7's that are tracked.
I bought the car with 26,000 miles and immediately converted it to a track car... so 15 track hours after having the car/motor done for $16K an exhaust valve broke and took out the motor. Pretty hard to argue about that
Old 05-02-2013, 06:38 PM
  #363
Cantevendrive75
I am considering a race prepped "CBM Motorsports" replacement engine... anyone have any advise or thoughts on that?
I would love to go with something like a "Katech Track Attack LS7" but the cost is absolutely astronomical
Old 05-02-2013, 06:45 PM
  #364
'06 Quicksilver Z06
Damn.
I appreciate your response and hate that you have to cover tha expense after so few hours of use of your car.
Good luck with the replacement engine.
It's a shame that they apparently thought that your stock valves were up to the task, when they were not.
Old 05-02-2013, 06:55 PM
  #365
azZ06Mike
azZ06Mike's Avatar
St. Jude Donor '11
Find a used ls7 get heads done and start over.
Old 05-02-2013, 06:56 PM
  #366
z0sicktanner
z0sicktanner's Avatar
Originally Posted by Dirty Howie
Wise advise. I pulled my heads to have SS valves etc done even though the car was running fine, not consuming oil and my BlackStone tests were ecellent. But I track mine and didn't want to blow up another motor. Good luck
DH
Howie wasn't your guides out of spec on the engine you have now. I know you went with wcch but when they pulled them they where out correct?
Old 05-02-2013, 07:53 PM
  #367
Cantevendrive75
I agree with the "Find a <insert something else here> and start over" remark... but used LS7's sell at such a high dollar value that its not really worth it... to me anyway. The LS7's abilities have been so "over blown" that anyone who has one (that doesnt have a hole on it) think they have the goose that lays golden eggs.
Anyway... I'm outa here... just thought I'd share my experience.
KV
Old 05-02-2013, 11:39 PM
  #368
Dirty Howie
Dirty Howie's Avatar
Correct. 2nd motor had 33K daily driving miles and 24 hours on the track. Guides were out of spec. Car did not exhibit unusual noise compared to first motor, burned no oil (except a little at on track days), and BlackStone was falling all over themselves saying how my motor was perfect. I also am very careful to get oil warmed up properly and keep it full. Plus I used Mobil1 0-40 on this motor. This was also a mid 2011 build.
DH
Old 05-03-2013, 12:17 AM
  #369
z0sicktanner
DH
Wow alot out of spec. that intake with .0052" I just got a set with .0056"on the intake side. the worst one was the exhaust side at .0141. guys that are running bronze guides ss valves or bronze and oem valves check your guides by 15k miles just to be sure.
Also that will help out the forum with the bronze results after running past 10k miles. mine are fine as far as a wiggle test goes after 22k. I'm getting ready to rebuild my transmisson next week while I'm at it I'm gonna pull the heads and get a bore gauge and get the real numbers. I'm dew for some new springs anyway I'll post up when I do
Old 05-03-2013, 01:09 AM
  #370
Dirty Howie
Chad
I have 7K miles and 6 track hours on the WCCH. In 10 days I will be at the track. By the time I get home I will have 8K miles and 8 track hours. I stood in Richards shop 2 times and asked him when I should change the springs (I assumed I should on some kind of regular basis). Both times he looked me in the eye and said not to worry about it for at least 100K miles. And he knows I track it at least once a month. He even became a sponsor for our local Corvette Challenge.
I'm thinking he is not worried about my springs because I am running the stock CAM.
Whats your opinion ?
DH
Old 05-03-2013, 02:26 AM
  #371
z0sicktanner
Chad
DH
The cam has a lot to do with it yes. but if your tracking the car I would get new ones by 50k you can change them without taking the heads off so for me it's worth it just in case. Richard is right really they should be fine. then again I've seen some springs lose seat pressure in 20k miles. If I remember right richard uses the Brian Tooley springs not a 100% sure but he uses great parts
Old 05-03-2013, 11:15 AM
  #372
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
Originally Posted by Mark200X
Curiosity got the better of me; it's been over a decade since I drove the Glen, and that was the 1967 configuration:
in a 1967 Lotus 49:
I really don't recall anything about it -- not even the layout -- since I spent much more time at Monza and Spa. I did some checking and this is the closest approximation of the original course:
The 2012 track layout has been in effect (absent the boot) since some time before 1972 (I did my 2nd SCCA driver's school there) so you didn't drive the 1967 layout a decade ago , but maybe 4 1/2 decades ago. I attended the Glen 6-hour in '67 when the old track existed. I think the F1 cars were running about 160 MPH average back then at WG.
Old 05-03-2013, 03:24 PM
  #373
Dirty Howie
Yes, BT Platinum Spring Kit
He says I'm good for 100K.
That doesn't mean I will wait that long
DH
Old 05-03-2013, 03:30 PM
  #374
0carlos@redline-motorsports
Former Vendor
carlos@redline-motorsports's Avatar
We got a stock LS7 Long Block complete with like 15K easy miles on it wrapped up in cellophane sitting on the shelf. If anyone needs one, please call or PM.
Old 05-06-2013, 10:45 PM
  #375
80atez
80atez's Avatar
Howie, your iron levels in your OA is a bit high. This is "normal" per blackstone for the LS7, but I wonder if it's those powdered metal (ferro-magnetic) exhaust guides before you did the heads...
My iron levels were always high (and read as normal per blackstone) and sho nuf, my exh valves were out of spec... If all the LS7's tested are track cars and eating their exhaust guides, they will all read high iron... That's my opinion, but my future OA's will tell for sure.
The OA's with only high iron were one reason I went for the wiggle test and then some.
Old 05-07-2013, 12:57 AM
  #376
Dirty Howie
Well you might be right. I just changed my oil but it won't be long before I do it again. I will be testing it this time and compare it to my pre WCCH samples.
DH
Old 05-07-2013, 05:29 AM
  #377
LT5 John
LT5 John's Avatar
DH
Howie, Richard used BT Platinum springs on my Brodix heads.
Old 05-07-2013, 10:05 AM
  #378
Dirty Howie
I'm hoping they are very good springs
DH
Quick Reply: [Z06] Another Z engine bit the dust yesterday
