[Z06] C6 z06 - clutch fluid reservoir changing
i found hard time to get my shifter to any gear i had to hit clutch two third times just to get it into a gear..so i did ranger method and look what i found in my reservoir....
im looking forward to hear from you guys..
should i bleed the clutch
and everytime i do it should i pump the clutch because i heard it will wear out the slave/master seal
You might think about detailing that engine bay while you've got the hood up.
