Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-21-2013, 08:21 PM   #1
BERETTA
CF Senior Member
Support Corvetteforum!
BERETTA's Avatar
Default 200 mph
Has anyone here been 200 MPH in a ZO6?
BERETTA is offline   Reply With Quote
Old 04-21-2013, 10:34 PM   #2
AtomicZ
CF Senior Member
AtomicZ's Avatar
yes
AtomicZ is offline   Reply With Quote
Old 04-21-2013, 10:49 PM   #3
BERETTA
CF Senior Member
BERETTA's Avatar
Quote:
Originally Posted by AtomicZ View Post
yes
Did your car feel fairly stable?
Old 04-21-2013, 10:59 PM   #4
FNBADAZ06
CF Senior Member
FNBADAZ06's Avatar
yes
FNBADAZ06 is offline   Reply With Quote
Old 04-21-2013, 11:14 PM   #5
BERETTA
CF Senior Member
BERETTA's Avatar
Quote:
Originally Posted by FNBADAZ06 View Post
yes
Do you have any idea the distance required to accelerate to this speed?
Old 04-22-2013, 12:04 AM   #6
db2xpert
CF Senior Member
db2xpert's Avatar
yes, and it was stable.
db2xpert is offline   Reply With Quote
Old 04-22-2013, 01:02 AM   #7
AzDave47
CF Senior Member
AzDave47's Avatar
Quote:
Originally Posted by BERETTA View Post
Less than 2 miles from a stop.
AzDave47 is offline   Reply With Quote
Old 04-22-2013, 01:19 AM   #8
BERETTA
CF Senior Member
BERETTA's Avatar
Quote:
Thanks, I have around 530 at the rear wheels. Are you stock or modded?
Old 04-22-2013, 10:15 AM   #9
AzDave47
CF Senior Member
AzDave47's Avatar
Stock. I've only been 197, but that was in a standing start 1 1/2 mile trap speed event. 173 in the mile.
Old 04-22-2013, 10:20 AM   #10
FNBADAZ06
CF Senior Member
FNBADAZ06's Avatar
This year, the Mile and Magnum events are on the same day !!!
I'm going to try and make it this year.
Old 04-22-2013, 10:23 AM   #11
AzDave47
CF Senior Member
AzDave47's Avatar
You should have a good run with the upgrades. You may break 200 in the Magnum, if you have the safety equipment to Tech for that.
Old 04-22-2013, 10:40 AM   #12
FNBADAZ06
CF Senior Member
FNBADAZ06's Avatar
I'm told they'll issue a 2 MPH buffer....I'd just like to have an official 200 MPH certificate. And, the current setup would definetly sail thru 200 in the Magnum......I'll lay off the throttle once I hit the number and stay within the legal and safety guidelines. I was impressed when you ran the number you did last year, given the weather conditions
Old 04-22-2013, 11:02 AM   #13
AzDave47
CF Senior Member
AzDave47's Avatar
They give a 5 MPH buffer in the classes. Check the rules for safety equipment. It is likely that you either have what's OK to Tech at 170 (+5) or Tech to 200 (+5). See: http://www.mojavemile.com/index.php?...d=10&Itemid=11
Basically to tech 200 you will need to do a mile run right near 150 if you've never run a similar event before, then they'll upgrade your driver classification for the next run in the 170 range then upgrade further.
For Tech 200 the driver will need a full race suit and arm restraints, helmet, gloves, etc. and the car will need Y or (Y) rated tires and at least a 5-pt harness. They Tech C6's for 200 with the standard roof (roll bar not required). I have a harness bar, 5-pt harness and full SCCA race gear including HANS.
PM me if you want more info, Victor.
Old 04-22-2013, 11:15 AM   #14
SilveradoSS500
CF Senior Member
SilveradoSS500's Avatar
I lost control at 175 and drifted...I saved it
It scared me lol
I had some lift occurring in a fender wheel, which is why this happened...
SilveradoSS500 is offline   Reply With Quote
Old 04-22-2013, 11:36 AM   #15
FNBADAZ06
CF Senior Member
FNBADAZ06's Avatar
I talked to them earlier this year, but I'll PM you later on your experience. you going again this year ?
Sorry for thread jack, OP.
I think the Mohave Magnum event is the ONLY event where a stock Z06 has any chance of of touching the 200 MPH....legally.
Old 04-22-2013, 11:51 AM   #16
AtomicZ
CF Senior Member
AtomicZ's Avatar
Quote:
It scared me lol
Why did you have lift? I've ran mine with stock aero over 175 dozens of times and the car is solid.
Old 04-22-2013, 12:24 PM   #17
AzDave47
CF Senior Member
AzDave47's Avatar
I'm probably done with the MM until I make mods to the car to go faster and that will probably be a while. The 196.5 was about all I could expect from a stock Z06 and the 173 mile at 3000'DA was about as good as I'd expect stock, also.
Old 04-22-2013, 06:25 PM   #18
erichg1000
CF Senior Member
Dave what did your speedo read to get 197 trap?
erichg1000 is offline   Reply With Quote
Old 04-22-2013, 06:58 PM   #19
Painrace
CF Senior Member
Painrace's Avatar
Send a message via AIM to Painrace
Yes, but I have Katech motor and modified aero!
Jim
__________________
PAINRACE
Painrace is offline   Reply With Quote
Old 04-22-2013, 07:41 PM   #20
AzDave47
CF Senior Member
AzDave47's Avatar
Quote:
I think the HUD indicated 198 right after I went thru the traps at official 196.5, measured for the 132' ending at the 1 1/2 mile mark. I was running nearly new M PSS in the stock 325/30-19 size and 34 PSI cold.
I don't normally expect the HUD to be that accurate as it usually 1 MPH high at 70 MPH indicated; the speedo is another 1 MPH off at that speed. Maybe there is some tire growth at the high trap speeds although the DIC was indicating 141.3 MPH average for a true 140 in the Silver State Challenge event. Now that the tires are worn I expect more of a variance.
I got an odometer reading of 91.3 miles over the 90.0 mile Silver State Challenge course with the nearly new PSS and got 88.8 miles indicated over that same distance with the somewhat worn Nitto NT-05's in 335/30-19 size.
For the Silver State, I drive up to Ely, NV in the reverse direction of the course and calibrate the odometer the day before the event with the tires I'll run, just to get a better idea how far off the odo and likely DIC average speeds are to help me get the car close to my target average speed in the event. In the last two events I got 2nd places with variances of 0.19 and 0.26 seconds over the 90 mile route, using the in-car data, a stopwatch and the mile markers (they go by fast at 140-160 MPH.
OP, I hope this is all of interest to you and not a thread hijack.
Reload this Page 200 mph
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
