[Z06] Wiggle Test Done Today At Dealer- Results As Expected
#61
[QUOTE=Les;1583428842]
If you're out of warranty you'll need to find what makes you most comfortable, whatever that might be including nothing- I'm not going to get involved in that debate. If you're still covered by any type of warranty, I suggest you find a dealer with a reputation that even approaches the one that Rich (and Abel Chev.) has. I realize that's a big challenge and I wish all you guys well with it. The inspection should take less than 2 hours to do at whatever their shop rate is. For me it would have been $238 IIRC. I'm choosing my route because the work is covered under warranty and I will maintain that coverage. Based on what I heard today, they don't seem concerned about the valves themselves. I trust them- you folks can take that for what it's worth to you. I'm hopeful that these fresh heads have corrected whatever the problem is. GM's statement describing a machining error and Jason at Katech's recent statement regarding a concentricity issue could be consistent with one another. I'm hoping so and also that it has been resolved.
QUOTE]
I know this is a little off topic but... does anyone know of a dealership within a few hours of the Fort Gordon/Augusta GA area that has a reputation close to that of Rich/Abel Chevrolet???
QUOTE]
#62
Pete
#63
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,426 Likes
St. Jude Donor '08
Rich is a stand up guy, and so is the entire staff at Abel. I always drive for more than an hour just to have them work on my car.
The only interesting thing about what you said is that the last time I was there (been awhile now), I spoke with Rich and the head Corvette mechanic and they had both only seen like 1 or 2 cars with valve problems. One of them being a C5 at that.....and since almost every Corvette in the Bay Area goes to Abel, that made me feel better.
I'm interested in seeing if this has now changed, and what their take is on this whole issue. Hopefully Rich will see this thread and chime in.
Last time you were in here (approx 6 months ago) GM had not released the bulletin on how to "deal" with the valve guide issue that's been beaten to death on the internet. To date, we have only had TWO stock LS7's fail due to an exhaust valve failure. Keep in mind the rather large number of Corvettes we see on a monthly basis. We have seen a couple additional failures that related to a valve failing, but they were in heavily modified engines (mine being one of them) or track use cars only.
Now that GM published a bulletin on how to handle the issue, we have a clear path to proceed down if a customer has a valvetrain noise, excessive oil consumption, oil smoke at start up etc. It is clear cut that IF the customer has a concern listed above, a valid warranty on an un-modified car and they are willing to pay the inspection fee if nothing is out of spec, then we are to proceed as directed in the bulletin. I tell every customer that comes in for an inspection that a guide that's out of spec does not mean the valve is going to drop the next time you hit the start button. I still stand by my original belief that the issue is still considerably over blown on the forum.
We've recorded measurements of .016 on a 2006 Z06 that had seen over 30 track days and had 80k miles on it. No noise, no oil consumption and still running strong. The customer wanted to check the guides and after seeing the results, decided to repair the heads. That car was at a two day track event at Thunderhill the day before he dropped it off here. That is almost 5 times the limit and no signs of failure. Contrary to what the dozen or so of the common posters on this issue woud have you believe, having a guide measure .005 does not mean your car is going to blow.
I find the most entertaining part of all these threads are the people who have recently had their heads repaired and are now on a quest to push it on everyone else in the world.
Now Les tells us that the people at Abel Chevy, indicate to him that "the number of Z06s with bad guides vs. the number of Z06s they've checked is surprisingly high."
So I think the overall awareness of this issue, at least in here, is now at an all time high.
And that's a good thing.
I will say that 2 stock engine failures related to a valve failure is a remarkably low number when you consider the number of cars that I've serviced in our dealership in the last 7 years.
We are required to hold them here for up to 15 days after the warranty repair has been paid from GM. If they want, GM can request the parts sent back to their Warranty Parts Center for inspection. To date, we have only been asked for 1 set to be sent back. All of the others are sent back to GM's core processing facility and we receive our $150 core credit back that GM recently added to the heads. As of now, I have a stack of 16 heads that have been paid and are waiting to be sent back as cores.
#64
It is still hard to believe that they would do their inspection, whatever it was, and whomever did it, GM or the vendor, discover a problem, and then make little to no attempt to prevent those heads sitting on the shelf, and potentially with the same problems, from ending up in engines yet to be built.
Why wouldn't they just ask for any heads back, which might be on the shelves, and had not already gone onto engines, and exchange them for heads which had been produced after the February ??, 2011 inspection date?
Pull those heads from the shelves, and replace them with known good stock.
This way, none of the potential bad heads would have wound up in any engine produced after that February 2011 date, and apparently some of these heads did.
Regardless of how many heads the vendor built ahead of time, assuming a J.I.T. model, GM would only order in limited quantaties from the vendor each time based on an optimization of demand, shipping/delivery costs, and inventory/carrying costs. So any heads ordered and delivered prior to the Feb 2011 inspections would quickly be installed, and GM would have to place a new order, likely well before May 2011.
Does anyone even know at what point in the process the heads were supposedly inspected? At delivery? By the engine builder? Somewhere in between? Because if the heads are inspected immediately prior to being bolted to the block during engine assembly, then there should be no problem past Feb 2011 period.
#65
First off, thanks for the kind words and for being a loyal customer of mine for years. Hopefully the car is well and you are getting to enjoy it.
Call it awareness or whatever you want, but it certainly is at an all time high. However, I'm still not jumping on the band wagon. We have indeed witnessed a high percentage of LS7 engines that measure out of the serviceable limit, but as I stated above, I still do not feel that means the engine is about to grenade. If we are talking failures and using that as a measurement of how wide spread it is, then we are still very low. I wish that I could run a report on the number of LS7 powered cars we've serviced since their debut in late 2005, but I don't have a way to seperate one Corvette from the next in our system.
Thanks Jimmy. I wish that I could open satellite dealerships all over the US so that we could take care of all Corvette owners and change their mind about GM dealers.
But to you part in bold above, well, I haven't seen such.
What I have seen though, is those who have recently had their heads repaired, myself included, take the approach that anyone else, well they can do whatever the heck they want with their personal property. The outcome, only affects them and their wallets. Not me and my wallet.
It they want to put their old valves, springs and retainers into a new set of stock castings, then that's their business.
When a lot number of pharmaceuticals is found to be bad, or to have bad apples in it, then the company sends out a letter requesting the return of any of your inventory, and they are shipped back to the manufacturer, before being unleashed on the public.
It is beyond belief that known potentially bad heads, still on the shelves, would be allowed to go onto upcoming engine builds.
The other thing(s) that just won't go away is, what exactly did they supposedly fix in these "new" heads?
The real sticking point, is they say 2008-2011.
Well, we know for a fact, that heads were going bad, and guide wear has shown up in currently very low mileage cars, built well before 2008.
There are some low mileage 2006 and 2007 cars out there with the same problem.
Yet the bulletin said between 2008-2011.
Hello all,
LS7 Valve guide issue summary:
• Affects a small, number of '08, 09 ’10 and ’11 Z06’s
• GM discovered the condition through our cylinder head warranty data involving a very small percentage of our vehicles.
• Through inspection of returned heads, it was determined that a machining error in the valve guide had occurred at our head supplier.
• The quality issue has been contained as of Feb 2011 with 100% inspection of all heads.
• The most common customer complaint has been excessive valve train noise.
However if the condition is not addressed, it could result in engine failure. To date, where this condition has been observed, it has occurred early in the vehicle life.
What customers need to know: They should drive and enjoy their vehicles without fear. If their car demonstrates this condition, they are likely to hear unusual valvetrain noise first. If you have a concern regarding this issue on your personal vehicle feel free to contact me through private message on this forum and we will work to assist in resolving your concern. Feel free to contact me through Socialmedia@gm.com please put attention Evan in the subject. As always, vehicles that have modifications to the powertrain or the calibrations, are no longer covered by GM's warranty.
Sincerely,
Evan, Chevrolet Customer Service
Sincerely,
There is just too much about this that just stinks.
And having as part of their fix, the reinstallation, and reuse of parts which have been operating inside of known out of spec heads, for who knows how many miles, doesn't make it smell any better.
#66
Thanks to Rich for the post. My problem is my local Chevy dealer is not a Corvette person. They sell very few Corvettes a year. My car is an early 06, out of warranty. I would truly love to have it looked at, and if needed, have the heads replaced. As of right now, I do not hear any unusual noises. The car is stock as far as I know. I do not race, track, or abuse it at all. It has seen red line once since I bought it Nov. 2011. I don't mind spending the money to have it looked at, just dont know who to take it to.
#67
Supporting Vendor
St. Jude Donor '08
Good information.
I agree that people should do whatever makes them sleep better at night, but I don't think people should stop enjoying their cars because of this issue.
#68
I typically don't get on band wagons that easily, however in this case the risk IMO is just too big, I'd rather spend 2,000 bucks on re-built heads, pick up some HP, than be trying to figure out how to come up with say 13,000 bucks for a new engine. I am not one to say "go out everyone and buy heads or your motor will blow" but I am looking at this very cautiously
Actually, anyone who has warranty, I would just say enjoy the car and don't worry about it, thats what warranty is for.
To each his own.
#69
Supporting Vendor
St. Jude Donor '08
#70
Come on Ricky, you know that I luv ya, but you are guilty of the above. Every valve thread in the last couple months has been bumped to the top with your unparralleled quest to make people feel inferior if they do not immediately pull their heads and send them in. I know that it's human nature to justify ones expense on modifications to their car, but you have recently taken it to a whole new level.
#71
Go ahead and tell us.
If getting a new set of castings and installing previously used exhaust valves, which have been running in out of spec guides for God only knows how long, is OK for these other folks, well then why not in your own car?
And especially for those out of warranty, what would you suggest that they do?
I'll say this again. Nobody in here is on any type of mission to make others follow the same route as they. But there are others in here who don't have warranties, and who are a considerable distance from Abel Chevrolet, and need to know just as badly, just what their options are.
You know this goes a whole lot deeper when you are talking about that portion of our membership which is out of warranty, or headed out of warranty and considering aftermarket warranties, and news like this, that one more warranty option which they once had, from a supposedly reputable company, is no longer going to be available, comes out.
http://forums.corvetteforum.com/c6-z...one-sales.html
It's easy to talk about how you "find the most entertaining part of all these threads are the people who have recently had their heads repaired and are now on a quest to push it on everyone else in the world", when your own heads are fixed and have been running strong and for a period of YEARS, and in a different manner than GM's current recommended fix, while there are others out there out of warranty , and with aftermarket warranty options diminishing, who want and need to know, what their options are.
#73
My 2007 was built in 2006, so I'll check when I get them back if the stamp is 05 or 06.
Either way they will be 100% inspected when I get them back.
I partially agree with the statement that out of spec != dropped valve.
Out of spec --> more out of spec --> way out of spec --> maybe dropping a valve
Much like changing the oil at 3000 and 70% DIC, 5000 50% , or 10000 0%
I'm a 3000 or less guy, so I pulled my heads.
Total cost with the labor being done myself is about $970
Gaskets/Bolts $140
Guides/Valves $200
Dual Springs $220
Machine work $410
I didn't include oil or coolant, both are due for me anyway.
I don't consider 950 a big spend for the Z. It is well worth it for the piece of mind. Much like the extra $200 every 10000 miles is worth it to be a 3k oil changer.
I am, however, still bitter. Until that bitterness fades, the avatar will be a Ford product.
Gaskets/Bolts $140
Guides/Valves $200
Dual Springs $220
Machine work $410
#76
Good for you Andy.
Thanks! Between your thread and some other info I gathered recently, I actually would have been more surprised if my valve guides were within spec. Best of luck to you too.
#77
Supporting Vendor
St. Jude Donor '08
With all due respect Rich, and you know I love you too bro, but how are your own heads done?
My original engine, when it blew, left no salvagable pieces to use on a new build. I had to buy two new head castings, block etc... Those castings were sent to WCCH per Jason's recommendation, while my shortblock was being built by Katech. There was a misunderstanding between WCCH and myself and somehow my heads were assembled with stainless valves. I was under the impression they were going to be assembled with new hollow valves. I wanted the lighter weight valvetrain and I will be building a new set of heads with Ti intake and exh valves to put on the car soon.
I had warned people about purchasing extended warranties from out of state dealers multiple times on here. We have had customers be denied claims because of that very reason and our rep had told us the internet dealers were going to be stopped.
Believe me, I do feel bad for those with stock cars out of warranty that have a failure. I work with my customers to find the most economical way to "prevent" or fix a failure on a daily basis. While I know the problem seems to be very wide spread from what you read on here, I have to go off my personal (and somewhat professional) experience that I've gathered in the real world. It's fairly compelling to me that in 7 years managing a dealership and literally thousands of repair orders on Corvettes, we've only seen 2 failures on stock LS7's that can be related to a valve issue.
#78
1 Post
#79
back to the age of the heads i kno i have to pay a inventory tax on anything stock i have on my shelves or inmy case on the ground so y wud GM want to pat a tax for 18 months on heads?
#80
I think that you know my real story behind that because it's posted in one of your threads regarding the solid valves.
When I read your prior post from back in 2011, it just didn't come accross as a misunderstanding, was all.
This, and what you have to say below about the warranty situation, was actually of some significance when I made my own decision:
Here's my attempt at actually answering the question:
-Replace OEM exhaust valves with Ferrea or equivalent SS exhaust valves
-Install Ferrea or equivalent bronze exhaust valve guides
-Install a Comp Cams trunion kit on OEM rockers or replace with aftermarket roller rockers like Yella Terra, Harland Sharp or equivalent.
-Replace OEM valve springs with Manley, PAC or equivalent valve springs and titanium retainers (optional with stock cam).
-While you have the heads off, consider port and/or mill work (more for cammed applications).
-Install an ARP head stud kit.
-Optional, but consider bronze valve guides for the intake valves as well while you have the heads off.
I'm not a pro by any means, so the list above is only what I've gathered through a little research. If there are better parts or other recommendations, please feel free to chime in.
It sounds like you got it all covered. I suggested calling Richard because he sees boat loads of these heads and ia an expert on cylinder heads. The problem with the forum is even though we have a lot of experts, you will get 15 different answers from each of them.
I knew that was coming.... Vehicle One has always required an inspection as part of selling their warranties. Obviously, when you break the rules, it will only last so long before you have your hand slapped.
It was actually after reading more than one warning in your prior posts, that I began to become uncomfortable with whether or not my warranty would cover me should the worst happen.
At that point, I ultimately cashed it in and went the same way that you had on the heads.
The thing here though, is that even guys who would now go about getting the formal inspection in order to get a good warranty, have now lost one of what was considered one of the stronger warranty companies, as an option.
You shouldn't use me as an example because my failure was my fault for heavily modding a car with a cam, headers, coil overs, sway bars, better brakes, Hoosiers etc and then expecting it to last multiple days on a road course.
