C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] metallic scraping noise
Old 03-12-2013, 08:51 PM
4th Gear
880's Avatar
Default metallic scraping noise
hi guys,
I have a 2011 Z06 with ~18k miles. It started making some noises 2 weeks ago. I have a feeling it's something related to rotor/caliper/brake pads.
I'm going to take off the rotor this weekend and measure it to see the highest/lowest point. Also look at the brake pads and calipers.
What do you guys think?
Thanks!
* metallic scraping noise that corresponds to wheel revolution
* pulsating brake pedal when slowing steady to a stop
* scraping noise is more noticeable when making a wide left turn
* noise and pulsating only comes after at least 30 min of driving; noise does not appear when first starting car after 5 day break; takes a while of driving for noise to appear
* front passenger rotor has 2 deep groves, can see brake pad imprints on a section
* brake pads are still good, pins don't look like touching the rotors
* jacked up car and tugged wheel at 6&12 oclock positions, no play
* didn't see any rocks or anything else hitting rotor
Old 03-13-2013, 01:37 AM
Alberta_Z06
Alberta_Z06's Avatar
Do you think perhaps you are chasing two different symptoms...pulsation vs metal scrapping? Once you actually take the calipers off, you might find the cause of your noise and/or pulsation.
For me, I had a scrapping sound emitting from the brakes when I would load the car to the right; especially under wide turns at speed (30mph+). It was a very tinny sounding scrap. It turned out to be the anti-rattle clip (not sure if that's what it is actually called) was rubbing on my rotor slightly. Bent it back/corrected it and all was good.
Good Luck
Old 03-13-2013, 09:08 AM
LMBTom
LMBTom's Avatar
Sounds like you have at least one uneven/warped rotor and something scraping (probably that clip that Alberta mentioned), likely against the passenger rotor.
New OEM rotors are only about $80 each (if you have the standard Z06 brakes), though you're likely covered under warranty.
I wouldn't worry about brake pad imprints. I've always get that after washing the car and letting it sit for a while afterwards. They wear off after some hard braking.
Old 03-13-2013, 11:10 AM
capevettes
Support Corvetteforum!
capevettes's Avatar
Received 4,550 Likes on 2,160 Posts
2016 C2 of Year
2015 C3 of Year Finalist
Sounds typical of one or more warped rotors.
Old 03-14-2013, 04:28 PM
truckplay
truckplay's Avatar
While the wheels are still on and off the ground, shake the wheel up & down and side to side. You may have a wheel bearing going out.
Old 03-25-2013, 09:50 PM
4th Gear
880's Avatar
I replaced all 4 rotors with oem rotors and brake pads with carbotech 1 piece. Went for a test drive and bedded the pads. No more noise!
Thanks for all the suggestions!
Old 03-26-2013, 10:26 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 03-26-2013, 07:03 PM
jedblanks
jedblanks's Avatar
If you still get the pulsating, might try new brake fluid. Maybe moisture got into it somehow.
Old 03-27-2013, 07:19 AM
capevettes
capevettes's Avatar
2016 C2 of Year
Once in a while we get it right
To metallic scraping noise
Quick Reply: [Z06] metallic scraping noise
