[Z06] stock clutch pedal and drag racing
Who is drag racing on stock clutch? I have stock clutch and have stuck clutch pedal issues. I have used Ranger method for bleeding and still have stuck pedal issue. I have been considering replacing clutch but wonder if i will have same problen with pedal.
Nope, replace the clutch if you don't want any more issues. The stock clutch can get you by, but no matter how many times you change the fluid you still can't slip it to get the best 60'.
I'm have a Mantic twin disk. A few guys are running the McLeod RXT and RPS. Some are running the Katech clutch. Any one of those are a huge improvement over stock.
Either is a good choice. I love my Katech LS9X clutch, but others like yourself are having great luck with, and nothing but great things to say about, the Mantic twin disk.
I have the same issues and on stock clutch. From what I understand, it's not the clutch. It's the master cylinder. Once you replace with a TIK, problem is solved...$300-400. This is what I'm going to do as well!
Banned Scam/Spammer
550 to the wheels and still on the stock clutch. Until it goes out I will abuse it as much as possible. Best 60 ft on stock has been 1.9
When it goes out a twin disc will work for me just fine.
I can't seem to keep pedal from sticking no matter what i do,its just a matter of time
My best 60' was yesterday with a 1.6. I'm at 510rwhp bolt-ons and stock clutch. Master cylinder is the problem; it heats up on burn outs because the of the hard braking.
It doesn't. A lot of ppl spend money on the clutch and still get the pedal to stick. Clutch Master Cylinder is the problem. Do a search on it and you will find that it's being replaced by a Tick!
Yes, a lot of ppl do. Most ppl swap out their clutch in hopes to cut better 60' or to combine with higher power applications; however, I believe that you can push the car in stock or near stock for to the max and really learn it and get great performance numbers before spending money in upgrades. The stock clutch is good for a good time. I have 47k miles on mine. I don't always putt putt around with my car and at track, I hot lap as much as I can. I think money well spent goes into tires, plugs/wires, and fluids that break down with hard use. Good luck with your pedal issue. I'll let you know when I fix mine.
Banned Scam/Spammer
