Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-24-2013, 03:40 PM   #1
woodhawk
Junior Member
Default pebbles in lower sill
Hello..does anyone have a easy way to remove the small pebbles that gather between the lower rocker sill and the rear quarter panel ??
woodhawk is offline   Reply With Quote
Old 02-24-2013, 04:00 PM   #2
Unreal
CF Senior Member
Unreal's Avatar
Send a message via AIM to Unreal
Undo the few bolts that hold the rear fender liner by there and then just blow/shake them out.
Unreal is offline   Reply With Quote
Old 02-24-2013, 04:04 PM   #3
tim414
CF Senior Member
St. Jude Donor '12
Support Corvetteforum!
tim414's Avatar
Quote:
tim414 is offline   Reply With Quote
Old 02-24-2013, 04:10 PM   #4
jwmgr8
CF Senior Member
Easy to get out
Just be careful pulling fender out
Long term fix is filling inner fender gap with body. I used large cell foam rubber you can get at any hardware store. about 1 inch sq
jwmgr8 is offline   Reply With Quote
Old 02-24-2013, 04:15 PM   #5
Dutchman9900
Junior Member
After you blow the pebbles out get some black silcone and cut a small hole in the tip and squease some in from front to rear. put everything back together and no more pebble problem. Let the car sit for about a day to give the silicone a chance to dry abit and you're good to go.
Dutchman9900 is offline   Reply With Quote
Old 02-24-2013, 04:23 PM   #6
Joezone914
CF Senior Member
Joezone914's Avatar
Send a message via AIM to Joezone914
There is a TSB so if you are under warranty the dealer can fill the gap for you.
Joezone914 is offline   Reply With Quote
Old 02-24-2013, 04:50 PM   #7
GMuffley
CF Senior Member
Quote:
Permanent fix.
GMuffley is offline   Reply With Quote
Old 02-24-2013, 06:18 PM   #8
dmuellenberg
CF Senior Member
dmuellenberg's Avatar
Quote:
What TSB is that? I've never heard of or seen it.
dmuellenberg is offline   Reply With Quote
Old 02-24-2013, 06:41 PM   #9
JChastain
CF Senior Member
I would like to see a DIY on this. Not sure exactly where to put the silicone... Thanks.
JChastain is online now   Reply With Quote
Old 02-24-2013, 09:29 PM   #10
Vegas1500
CF Senior Member
Vegas1500's Avatar
Quote:
Would also like to know...........never seen it...
Vegas1500 is offline   Reply With Quote
Old 02-24-2013, 09:42 PM   #11
BearZ06
CF Senior Member
St. Jude Donor '09-'10-'11-'12-'13
BearZ06's Avatar
Link to a non-supporting vendor deleted.
Members are not prohibited from mentioning it when they have a good (or bad, for that matter) experience with a non-supporting vendor. But such mentions cannot be so specific (address, phone number, e-mail address, URL, price, part number, offer to send contact information via PMs, etc.) or so frequent that they become marketing and promotional references.
Last edited by JimTN; 02-24-2013 at 10:31 PM. Reason: Link to a non-supporting vendor
BearZ06 is offline   Reply With Quote
Old 02-24-2013, 09:53 PM   #12
QIKSLVR
CF Senior Member
QIKSLVR's Avatar
Excellent illustration. When the weather breaks, its the first thing I'm doing. Thanks for the posting!
__________________
Last edited by JimTN; 02-24-2013 at 10:32 PM. Reason: Link to a non-supporting vendor
QIKSLVR is offline   Reply With Quote
Old 02-24-2013, 10:57 PM   #13
MudZ06
CF Senior Member
^interested in the deleted info/photos removed above.
MudZ06 is offline   Reply With Quote
Old 02-25-2013, 08:30 AM   #14
WhiteDiamond
CF Senior Member
WhiteDiamond's Avatar
When the you remove the rear tire, you can get into the wheel well and see the gap that allows the small rocks in. I don't like the black silicon idea, but it works. Used some readily available foam from the hardware store and cut it to size to fill the gap.
WhiteDiamond is offline   Reply With Quote
Old 02-25-2013, 09:06 AM   #15
wolf8218
CF Senior Member
Please PM me the removed pictures. Thanks
wolf8218 is offline   Reply With Quote
Old 02-25-2013, 09:15 AM   #16
jwmgr8
CF Senior Member
What TSB????
Old 02-25-2013, 09:17 AM   #17
jwmgr8
CF Senior Member
Have not a clue where you put the silicone?? and why black?
Old 02-25-2013, 09:21 AM   #18
jwmgr8
CF Senior Member
Quote:
Originally Posted by jwmgr8 View Post
Easy to get out
The foam goes in the rear wheel well. You can feel the gap between inner and outer fenders .Fill with weather striping foam. it will keep rocks out. No need to take wheel off.
Someone referred to TSB- if there is one post number??
someone else mention black silicone cutting a hole?? better description is needed.
Old 02-25-2013, 09:32 AM   #19
"NO SHOW"
CF Senior Member
"NO SHOW"'s Avatar
Pics of this would be greatly appreciated.
"NO SHOW" is offline   Reply With Quote
Old 02-25-2013, 09:44 AM   #20
zeeohh6ex
CF Senior Member
zeeohh6ex's Avatar
prem1umunleaded fa1rladyz
where is the tsb?
zeeohh6ex is offline   Reply With Quote
Reload this Page pebbles in lower sill
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
