[Z06] Getting it done...
Getting it done...
Yup, you already knew what this thread is about.
I just setup an appointment with a local shop to get the heads swapped out on my car and will be doing a few other things while they're in there. Will be dropping the car off on Friday and she'll be gone for a few weeks as we wait for the turnaround from WCCH.
It won't be cheap but I'll appreciate the bump in power, confidence in the valve train, and fix the shortcomings of the stock oiling system in one fell swoop. Car will be missed for the month or so its out, but it'll be better than ever once I get it back.
Already have a set of PFADT headers, Halltech MF103 intake, ported intake manifold, and ported throttle body on the car.
List of new stuff is below...
If you have any feedback or suggestions on other stuff that I should take care of while I'm in there, please chime in.
Heads -
WCCH Stage 2 Heads
Ti Intake & Ti Exhaust Valves
Bronze Intake & Exhaust Guides
Trunnion Rocker Upgrade
Cam -
Custom Grind Cam (sorry, don't know specs), apparently quite mild, similar to stock drivability/idle and smoggable with stock exhaust manifolds if I needed to go pass the sniffer down the road.
Don't know the complete setup, but a local car with a similar cam and stock exhaust manifolds got mid-500rwhp. Headers should put me slightly above that or around that if I go more conservative.
Oiling System -
LS9 Oil Pump
LPE 9QT Expanded Dry Sump Tank
Aviaid Tank Insert
Aviaid Oil Pan Windage Tray
Heads -
WCCH Stage 2 Heads
Cam -
Oiling System -
LS9 Oil Pump
Aviaid Tank Insert
Heads -
WCCH Stage 2 Heads
Cam -
Oiling System -
LS9 Oil Pump
Aviaid Tank Insert
Heads -
WCCH Stage 2 Heads
Cam -
Oiling System -
LS9 Oil Pump
Aviaid Tank Insert
Welcome aboard Jawnathin, and good luck with the build. From what you have listed above, she will be solid as a rock.
Excellent choice on your heads going with WCCH. Be sure to go ahead and go first class with the C.H.E. rocker upgrade, and don't settle for less, and you should be good to go.
Your part in bold above, is the most important thing here.
Now you will have the reliability in that car which up until this point, was lacking, and you will get some additional power to boot.
Heads -
WCCH Stage 2 Heads
Cam -
Oiling System -
LS9 Oil Pump
Aviaid Tank Insert
Heads -
WCCH Stage 2 Heads
Cam -
Oiling System -
LS9 Oil Pump
Aviaid Tank Insert
Don't know yet. That was a big question for me as well. Ill see what Richard has to say and if he can't source them on his own, then ill source a set from Katech.
Good point on the CHE rocker upgrade and ill be sure to mention that when I bring the car to the shop on Friday.
Yup, the bold part is key. I plan on keeping the car for the foreseeable future and it doesn't make sense to have that lingering doubt looming over the whole time during my ownership. The car turned from a fun toy into a liability and it got to a point where it just wasn't fun anymore. With confidence in the car restored I look forward to driving her like it should be driven.
The reason I was asking, Richard is doing a set of Brodix BR7 heads for me, and was waiting for a price from Del West on the To/Mo exhaust valves. My Z, I am keeping for a very long time, and I will do what ever it takes to make the heads as bullet proof as possible...
If you find out more, please share, but I'll let Richard be responsible for sourcing them, whether its through Del West, Katech, or another vendor. They just need to be Ti and compatible with the Bronze Guides.
I'm in the same situation, I plan on keeping the car and wanted to change out the valves but keep them as close to the weight or lighter than the Sodium Filled valves as much as I could.
St. Jude Donor '12
That's what I'm thinking for my car.
Add: it can sure get spendy in a hurry. I totaled up what I think I wanted and dam, by the time I pay out labor cost, new engine....
Congratulations on your build! If your car is a '10 or earlier, I would recommend upgrading the radiator. Also, I would consider replacing the stock mediocre dampener with an ATI SuperDamper - 10% underdrive.
As for the heads, back last October I told Richard to build me a set of the Brodix heads like he would build for himself. I have the SS exhaust valves and can detect no difference in RPM spin-up or stability into 7100 RPM. Of course then, the existence of a Ti exhaust valve alternative was not known.
Going with the regular SS valves WCCH package keeps the cost down considerably. Once you start adding in these Ti valves and different springs and retainers, it all starts to add up to quite a bit.
I know people have had success with the SS valves and that is great news. For me, I would just feel better if I went with something that was comparable or lighter than the stock valves. If someone prefers the SS valves, then great, it seems to be a proven solution and it'll save you quite a bit of money over Ti Valves!
Thanks again!
Thanks Quick, appreciate all the information you've gathered and shared on the forums and that helped with how I approached this issue.
Words simply just can't describe the feeling of confidence regained in your sports car when you know that it is rock solid.
