[Z06] Valve Train Sound Test: WCCH vs Stock Heads
Mark
Rich has stock but different (ZR1 I think) exhaust. But I really don't think his meter is picking that up.
I think if you listen and compare the videos you will have a very good idea of what to expect. The camera sound level is static and was placed exactly the same on both cars.
DH
DH
St. Jude Donor '12
Sounds to me the stock is quieter. I have been wondering if doing heads/valves eliminated or at least toned down the tick. Mine is VERY pronounced (tick). It's more pronounced today w/13,xxx miles than it was when it was new.
I am at decision point as whether or not to purchase the GMPP. My 3/36 expires in the weeks ahead. There's no sense in it if I do the heads. But there are also other parts of the car which I just soon not have to buy/replace as well.
Decisions/decisions.
Thanks guys for answering my question.
Looking at the spreadsheet results, stock is quieter? That is interesting.
So is it safe to say that 'ticking' is just the way these things sound (injectors?) and not necessarily indicative of a valve train problem?
DH
Thanks for posting this thread. I've heard some comments here and there about how the rebuilt heads are louder than stock, and I am planning on having mine done soon so its nice to know there is a little expected difference . I guess if with the hood closed you can;'t really tell a difference it will not really bother me.
I will tell you now, my car as is with the stock heads, makes almost zero valve train noise... it is very very quiet. In fact, my LS7 is quieter than my LS1 (stock) was. That had a notable sewing machine tick to it.. my LS7 does not.
UPDATE
Minkster (Rich) came by today and we ran some sound tests again. I have been noticing how much quieter my motor is at cold start ups since I got my CAT replaced. It had a very loud exhaust leak.
Rich clearly heard that my motor sounded very quiet and the data showed it was as well, even quieter than stock. I postulated that it may have been due to the motor being warm and not hot as tested last time. I figured the thicker oil, increased oil pressure or thermal expansion was accountable.
Sure enough, after I ran it hard around the block for awhile the sound levels were back to where they were at the original testing.
Rich's meter is very accurate and our hot tests were almost identical to last time.
My camera battery died so I only have video of the warm run on my car. Sound clip is at idle and then held at 2K rpm. Oil temp was 155, oil pressure was 50 and coolant was 205.
THANKS RICH !!!
DH
THANKS RICH !!!
DH
Thanks for the tests fellows.
I don't suppose I could make a request though?
What about an in car driving down the road while staying at 1800rpm in say second or third gear comparison? From say center of the dash or passenger seat?
Mine is so much louder then before I'm getting ready to pull the valve covers off and check things.
I wonder if .010 decking of the heads is the reason mine seems so loud? Dunno...... but thanks for the tests.
DH
#34
Listening to the 2K RPM audio, it sounds like the WCCH is much louder - almost like it's at a higher RPM. The stock clip has audible noise, something I would associate with injectors based on the video.
Thanks for posting.
Thanks for posting.
