[Z06] Valve drop and engine heat
Among the schools of thought regarding the valve drop issue is one that centers on engine/combustion chamber temperature. I am not nearly smart enough to understand all I have read about this, but have one simple question that you more experienced types perhaps can help me with. After having my heads replaced with WCCH "stage 2", milled heads, and getting a new tune, I notice that my engine oil temperatures are much lower than prior to the R&R. It has been over a month now, and in various kinds of driving, I have not yet seen the indicated oil temperature exceed 150 degrees. Prior to the work, temps would routinely reach 170 or perhaps more...I don't really remember.
What I am wondering is this: is there a correlation between exhaust gas temperature and engine oil temperature? And if so, is 150 degree max oil temperature less than what would be expected if factory stock?
I do believe there is a link between SS valves and OEM Sodium Valves when it comes to oil temp, though I'm not sure if its to the degree that you're seeing. I will find out for myself once I get my car back.
Anyway, my theory goes like this.
The valve, no matter what type, will make contact with oil under the valve covers. Sodium Valves transfers more heat more rapidly than the SS valves do. Hotter valves = hotter oil temps.
However, I'd be surprised if it was significant enough to warm up 9+QTs of oil to the degree you're mentioning.
How was weather and driving conditions between the two configurations? If all you're doing is highway when its 50F out, your oil will stay very chilly.
Received 8,919 Likes
Valve temperature probably has more to do with how much power the engine is producing during any specific time period. If you are just loafing around driving down the highway in 6th gear at 70 mph the temps will be a lot lower than if you are at wide open throttle in 4th gear at 150+ mph. In the highway scenario the engine is probably producing 30 or 40 HP while in the track scenario it is producing closer to its rated 505 HP. The exhaust valve is going to get a lot hotter in the full power scenario and is going to transfer a lot more heat through the guide to the engine oil.
Bill
Bill
My driving has always fallen into the "loafing around town" category. Both prior to, and since, the head replacement. I bought the car new in 2006, and have accumulated 40,000 miles. The car has seen WOT maybe 5 times total. I mean, considering speed limits, traffic congestion, PoPo, poor road conditions, it is a rare occaision that my engine ever sees anything north of 4,000 rpms.
Perhaps it's just the combination of cool weather here in s/e TN, loafing around town, and the new tune. Perhaps I will see 170+ degree oil temps again when the 110 degree days of May, June, July and August get here. But I distinctly recall 170 degrees back in December and early January, before getting the new heads with SS valves. Perhaps the new tune activates engine cooling earlier/longer than was previously the case.
Anyhow, my engine now seems like it's considerably cooler than before.
Unless it's just my imagination.
But it probably doesn't mean anything anyhow.
Variation in fuel-air ratio has a marked effect on valve temperatures, as may be seen in figure 8. Reducing the fuel-air ratio from 0.112 [8.9:1 AFR] to 0.064 [15.6:1 AFR] increased the temperature of the exhaust valve more [and to a higher peak] than increasing the indicated mean effective pressure from 98 to 254 pounds per square inch, as shown in the following table:
http://www.dtic.mil/dtic/tr/fulltext/u2/a801184.pdf
Sr.Random input generator
The fact that this dropped valve issue happens to even those who take it very easy on the valve-train makes me believe that it is not necessarily a heat-issue, but rather a geometrical and/or material issue.
Whoever did your tune should be able to answer this question regarding oil temperatures. What did they say?
If someone is modifying the tune they need to have answers for this. As was pointed out, it may be something as simple as a fan being activated at a lower temperature.
This old military paper on sodium valves in aircraft engines indicates that the air/fuel ratio (which they are calling fuel/air ratio... divide it into 1 to get A/FR) has a greater effect on valve temp that a 159% increase in power (say, 100 HP to 259 HP). Unfortunately they are using a term -- Indicated Mean Effective Pressure -- that I cannot readily convert to HP.
This takes us back to earlier discussions that the exhaust valve may be getting overheated by closed loop stoichiometric operation (14.7:1 AFR). Loafing around at low RPM under load. Or not.
Bill
