C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Most power to be had without opening up the engine
Old 02-13-2013, 10:52 AM
yellowzron
Banned Scam/Spammer
yellowzron's Avatar
Real simple answer, every bolt on you can get. If your looking to get the most without opening up your engine. Get the snake charmer cai, the headers, the intake the TB, a tune and there you go. If you wanna spend about 3grand do the rear end and get 3.90's or 4.10's!!!!
If your looking for best bang for your buck, get a mild cam. It all depends on what route you wanna go.
Old 02-13-2013, 03:26 PM
obzidian
obzidian's Avatar
St. Jude Donor '09
Easy:
1. Full Bolt-on's + Tune + Nitrous (100-150hp)
Should put you (with a clutch and tire) in the 140mph+ range and hurting a lot of ego's.
Old 02-13-2013, 03:33 PM
ATC399
Support Corvetteforum!
ATC399's Avatar
Originally Posted by JwT
I just saw this issue Saturday on Horsepower TV. They strapped a stock Z06 onto a dyno and did the test runs. I think the stock numbers at the rear wheels was around 465hp. They then installed an HP Tuner with a computer and managed 504hp at the rear wheels. Perhaps someone else can remember the torque numbers.
saw the episode also...it was a Dynojet if it matters some say they rate high
Quick Reply: [Z06] Most power to be had without opening up the engine
