[Z06] c6 z06 dropped exhaust valve
My 07' c6 z06 dropped exhaust valve and I will be needing to replace the engine , any ideas or any helpful tips I can get from you guys will be much aprreciated I am new to this forum , thanks
Supporting Vendor
Depending on whether or not you can do your own labor (or at least get it done at a reasonable price) you'd be surprised at how inexpensive the job could end up costing.
Case in point - I recently bought a short block that had dropped a valve, ruined one of the heads, cracked the sleeve in the cylinder and damaged the piston. Despite all this, I ended up getting the entire motor rebuilt with new rings and bearings (using a spare piston that I had from another motor) including having the cylinder resleeved for just over $2400.
Given that you probably still have one good head, you could probably get away with having your total bill end up being around $3000 when you factor in the cost of buying a single head.
In case you're wondering as to how well a rebuild like this will hold up, I ran a 10.09 with my car (it's a regular C6 with an LS7/A6 combo) two weeks ago on my first pass of the day and on the second, I ran what would have been a high 9 second pass but unfortunately snapped my differential and transmission output shaft on the 2-3 shift.
Good luck regardless of what you decide to do with it.
Christopher
OK, this just brought me over the top. I just ordered new PRC LS7x 268cc heads with 11.2 compression from Texas Speed as a replacement for mine. Not that I have any valve train noise but I just hate the idea of having a hole in my block.
Hopefully in two weeks I have my peace of mind......
another new member joins up, and on the same day posts about a dropped valve?
I'm not saying it's all coincidence, hoax or conspiracy (I recall another scenario where the scenario was similar, but the poster turned out to be legit) - just odd.
Not the first person to mention that, but I've yet to see a hoax.
I'm not second guessing the OP, but is it unusual to have a completely stock car with just the cats removed? Wouldn't the cat delete at least require a tune?
It really doesn't matter if the OP is lying or not Ls7's are falling like flies.
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
It is odd but done more than you might think, at least back in AR while we lived there. I know 4-5 folks that did this. They just liked the sound better but boy did those cars stink.
More posts on another Corvette forum by the OP, without a cat.
http://www.z06vette.com/forums/f64/z...d-help-125682/
St. Jude Donor '12
http://www.z06vette.com/forums/searc...g_searchinfo=1
what if i was to buy extended warranty for my car, wait couple of weeks then report that my z06 engine failes, do you guys think this will work? a new ls7 is about 14000 , or i would have to get it repaired
