Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-03-2013, 01:06 AM   #1
Dirty Howie
CF Senior Member
Support Corvetteforum!
Dirty Howie's Avatar
Default ABS Unit Leaking !!
PN on my unit: GM ASM PN 25886839 EBU(?) 25866840
My ABS is leaking from the fitting/port in RED.
Is this repairable?
Is there any reason this cannot be sealed with JB Weld?
Is there a function to this fitting/port?
Is there any solution other than replacement?
Is there a source other than new from GM?
Click the image to open in full size.
DH
Dirty Howie is offline   Reply With Quote
Old 02-03-2013, 01:36 AM   #2
'06 Quicksilver Z06
CF Senior Member
'06 Quicksilver Z06's Avatar
Quote:
Is this repairable?
DH
So, what it is you're needing? The modulator valve? Part #2? #89060303
http://www.tonkinonlineparts.com/sho...ssembly=852894
http://www.gmhightechperformance.com.../photo_10.html
I'm not sure, but I think you might have to buy the whole kit, which is GM part #89060341, Part #89060303. That includes part #4 along with part #2.
At any rate, you'll need to do some shopping around Howie.
That part 89060341, the control module, runs $628.55 at GM Parts Direct. If you shop around, you can get it for less. The auction site, you can get it for about half that.
Part #89060303 the control modulator, runs $479.63 at GM Parts Direct.
Anyway, here is another diagram
http://store.gmpartshouse.com/parts/...agramCallOut=1
Hopefully you can get by with just part #89060303
'06 Quicksilver Z06 is offline   Reply With Quote
Old 02-03-2013, 02:11 AM   #3
Dirty Howie
CF Senior Member
Thanks for the help Ricky. My leak is from that recessed round port/fitting below where #5 is on main block part #2.
Im not clear which is which. Is the control modulator #2 or #4 ?
DH
Old 02-03-2013, 02:19 AM   #4
Dirty Howie
CF Senior Member
Okay checked diagram and parts numbers. I see that the leak is in the modulator part which is less expensive than the control module part.
Thanks for those price checks.
DH
Old 02-03-2013, 02:20 AM   #5
'06 Quicksilver Z06
CF Senior Member
DH
In the above diagram, it looks to be #2
In this one linked to below, it looks to be #2 as well.
The module in this diagram below is #1. or #4 in the above diagram
The module, or that back piece, is the more expensive of the two.
I recall reading somewhere in the C5 section, a few of these going bad, and the owners getting good will repairs out of warranty.
If that doesn't work, then I have seen a few of these on the internet for sale.
But I'm almost certain that whenever you fool with that block, you need a Tech 2 when you go to bleed your brakes again.
That's why when people bleed their brakes, or change brake fluid, they never bother with that block and some of the old brake fluid remains in it.
Anyway, you might try the guys referenced in this thread too.
http://forums.corvetteforum.com/c5-g...ol-module.html
Old 02-03-2013, 01:36 PM   #6
383vett
CF Senior Member
383vett's Avatar
The C5s did have a problem with the abs module. When I had an 02Z, I sent mine to a company back east (can't remember the name but can be found with a search). A lot of guys were sending them out for a rebuild for a couple hundred bucks. It took care of the problem and was much less than buying a new one.
383vett is offline   Reply With Quote
Old 02-03-2013, 02:08 PM   #7
Dirty Howie
CF Senior Member
Quote:
I think you are referring to absfixer.com which Ricky in the above link, and someone in my other thread pointed out.
But I can't have my car down while its removed, shipped, repaired and returned
DH
Old 02-03-2013, 02:17 PM   #8
'06 Quicksilver Z06
CF Senior Member
DH
Simple matter.
You may be able to buy a core in here, or at a salvage yard, or they may have some ready to ship out.
Give them a call.
Old 02-03-2013, 02:31 PM   #9
Dirty Howie
CF Senior Member
Simple matter.
Give them a call.
I put up a WTB thread and have found some on auction site .......
Will be checking later and tomorrow on prices. Likely will be close to same price buying use one in good condition as buying core and repairing. But am open to any ideas as long as its quick
DH
Old 02-03-2013, 03:25 PM   #10
Dirty Howie
CF Senior Member
WHY IS THE PN ON MY UNIT DIFFERENT ????????
DH
Old 02-03-2013, 03:29 PM   #11
CanadaGrant
CF Senior Member
CanadaGrant's Avatar
DH
Your right Howie. Absfixer is for repair of the electronics card inside the abs module that was triggering an abs light in a bunch of C5's. It has nothing to do with a fluid leak in the actual unit.
CanadaGrant is online now   Reply With Quote
Old 02-03-2013, 03:53 PM   #12
'06 Quicksilver Z06
CF Senior Member
DH
I don't know.
How much is it?
Old 02-03-2013, 04:15 PM   #13
383vett
CF Senior Member
383vett's Avatar
DH
Because you need to fine the pn of a leaky unit.
Old 02-03-2013, 08:07 PM   #14
Dirty Howie
CF Senior Member
I don't know.
How much is it?
Ricky, can you or anyone else check the PN on their ABS units? Its easy to see. Drivers side, front of motor, in front of alternator.
DH
Old 02-03-2013, 08:12 PM   #15
Dirty Howie
CF Senior Member
Seriously, I need to figure out if there is more than one part number for this unit. If I buy a used one I need to know its right. And need to make this happen quickly.
I thought I would see the same PN that Ricky found but its not.
DH
Old 02-03-2013, 08:22 PM   #16
erick_e
CF Senior Member
St. Jude Donor '13-'14
erick_e's Avatar
DH
Howie,
From what I have seen, these units have multiple part numbers. The number on the unit, which you have seen as multiple part numbers are the manufacturer part number, and they change with the calibration level installed.
Just be sure to get one with the correct GM part number, which will probably not be identified on the unit.
It will probably have to be programmed to your VIN anyways.
erick_e is offline   Reply With Quote
Old 02-03-2013, 08:53 PM   #17
Dirty Howie
CF Senior Member
Quote:
Originally Posted by erick_e View Post
Howie,
Erick
How am I supposed to know if I am getting the correct GM part number if it doesn't show on the unit ???????
So I am curious to see what other have for manufacturers PN. Can you check yours?
And I assume you mean the TechII will program the unit.
Man, this is confusing.
Thanks for your help
DH
Old 02-03-2013, 09:56 PM   #18
erick_e
CF Senior Member
erick_e's Avatar
Erick
DH
I wish there was an easy way to identify the GM part number, but as far as I know there isnt.
My car is in the shop having the valve guides checked, so I can't take pictures of that module. However, I took pictures of the 2010 module I bought that I was going to use to add traction control.
I wish there was an easy way to identify the module, so you may just have to trust the seller or get one from a vendor.
A Tech II will be required to program a new control module ( the black electronic module) to your VIN, but if you just need the BMPV (the aluminum cylindrical part) you could replace that without programming.
Old 02-03-2013, 10:19 PM   #19
BEZ06
Formerly beezeye
BEZ06's Avatar
.....I took pictures of the 2010 module I bought that I was going to use to add traction control.
Huh???
All years and models of the C6 have Traction Control!!
Bob
BEZ06 is online now   Reply With Quote
Old 02-03-2013, 10:30 PM   #20
BEZ06
Formerly beezeye
BEZ06's Avatar
That picture is of the Bosch EBCM used in the 2009 and newer.
I believe Howie's car is a 2008, which requires the ACDelco unit.
The two are not interchangeable!!
Bob
Reload this Page ABS Unit Leaking !!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
