[Z06] ABS Unit Leaking !!
Oh!!
Im pretty sure that Launch Control is in the ECM/PCM - whatever you want to call it. I think you'll need a 2010 ECM and you'll need a 2010 VIN programmed into it.
The only guy I know of that really knows how this works is Chris White. I know he has put LC into his own older model Z06.
Check out his site for his contact info:
http://www.whiteautoandmedia.com
Bob
Bob
http://i.ebayimg.com/t/05-08-C6-Corvette-Z06-XLR-OEM-Anti-Lock-Brake-Pump-Unit-Module-Complete-ABK-/12/!Bw(iNiQCGk~$(KGrHqQOKiwEwPuEU4,3BMImri4 FKQ~~_3.JPG
Here is one that does actually have the GM number (89060341) on it but it from a base C6 and does not have the Z0 designation like mine and the other part in previous picture.
DH
DH
Oh!!
Bob
Bob
http://forums.corvetteforum.com/c6-t...-corvette.html
Thanks for checking. Must be the model year changed something.
Anyways, I just found one from an 08 with 12K miles and it has the same PN as mine ............. so I'm getting it
DH
