C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] 1st Time to the 1/4 Mile Track...
Old 02-02-2013, 11:51 PM
briancb1
briancb1's Avatar
Default 1st Time to the 1/4 Mile Track...
Today was my first day taking my Z to the track since I purchased it last summer.
It has a built motor, Pfadt coilovers (fairly stiff), and MT 315/35x17 Drag Radials.
The best I was able to perform was a 10.7 ET, 132MPH Trap speed, 1.7 60ft time.
The absolute hardest part was getting past the 1.7 60ft time... The rear coilover suspension was not giving enough and needed some type of adjustment that I couldn't perform at the track. It seemed if I gave it any more throttle it would just basically just hop and get a little crazy....
I feel there is much more for me to learn and the car def has at least another half second off the ET judging from my marginal launches.
Oh well, there is always next time. Just thought I would share my small victory for the day.
Old 02-03-2013, 12:07 AM
C6z06man
C6z06man's Avatar
Not bad. Definitely seems you need to take some preload off the rear springs. Maybe a little lower air pressure. Depending on what you were running! Glad to see you out racing.
Old 02-03-2013, 12:12 AM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Excellent. Especially for the first time out.
Old 02-03-2013, 12:44 AM
LanceFitzgiben
LanceFitzgiben's Avatar
definitely no real drag experience here but I've got my Pfadts set pretty damn soft in the rear to get enough weight transfer to the back. I road course track the car so it's not full soft or anything but the rear is considerably softer than the front.
I get pretty good transfer and power-on traction has gotten a lot better.
Old 02-03-2013, 02:07 AM
z0sicktanner
z0sicktanner's Avatar
Wow nice first time out..
Old 02-03-2013, 03:03 AM
FNBADAZ06
FNBADAZ06's Avatar
It's all in the launch, with your clutch and throttle foot work. Switching to the Hoosier DR will help as well, with the Hoosier recovering much better from wheel spin than any other DR.
Excellent job for you first time out
Old 02-03-2013, 03:50 AM
briancb1
briancb1's Avatar
Thanks for all the kind words!
I got to the track, set the tires to 15psi and ran with them for a while. They eventually got to 18psi so I dropped them back down to 15psi again.
As for the Pfadts, I need to find some instructions on those guys and try getting it a little softer for sure, hopefully that helps.
As for Hoosiers, I'll have to wait till the MT's are gone as I just got them
Thanks for all the pointers.
Old 02-03-2013, 06:10 AM
Rock36
Rock36's Avatar
A 1.7 60' isn't bad at all man.
Old 02-03-2013, 09:06 AM
COVERT GUY
COVERT GUY's Avatar
Congrats, damn good driving. What kind of power are you putting down to the wheels?
Old 02-03-2013, 09:37 AM
timmyZ06
timmyZ06's Avatar
whats kind of built motor?
I/C/H, supercharged, whats the whp ?
it might not be too bad depending on the power level
Old 02-03-2013, 01:30 PM
carpe dm
carpe dm's Avatar
Old 02-03-2013, 04:03 PM
SS MPSTR
SS MPSTR's Avatar
Agreed. Do you happen to know what the DA was?
Old 02-03-2013, 04:20 PM
Turbosixx
Turbosixx's Avatar
Not bad at all. Launching these cars is an art in itself. Running 10's the first time out is very good.
What clutch are you running?
Old 02-03-2013, 05:23 PM
NachosZO6
NachosZO6's Avatar
Since Brian's asleep at the wheel, I'll answer for him. Hope he doesn't mind.
RXT clutch. 454CID n/a with stock LS7 heads worked by Darin Morgan and a custom cam by someone whom I don't remember and is putting down 600rwhp.
Just needs to work on launch and ahift points, and he should run a low 10 sec pass. Proper tire as well.
Old 02-03-2013, 07:26 PM
briancb1
briancb1's Avatar
Haha thanks for being my rep Nacho.
Old 02-03-2013, 07:50 PM
Lethal427
Lethal427's Avatar
Congrats!! For a manual and first runs, I 'd be happy, keep us posted on your progress!! Good luck !
To 1st Time to the 1/4 Mile Track...
Quick Reply: [Z06] 1st Time to the 1/4 Mile Track...
