[Z06] My 10.6 Pass Video
My 10.6 Pass Video
Sorry for the video quality...I forgot to turn on the night mode. I haven't had alot of track time lately. I found the 345-30-19 are tough to launch on, im using the ls9r clutch. The tune is conservative as I have been using this as a street tune and did not have alot of time to tune at the track. I was only able to get a few passes in. There is still definately more left in it. car is on stock rims full weight full tank of gas
Sorry for the video quality...I forgot to turn on the night mode. I haven't had alot of track time lately. I found the 345-30-19 are tough to lunch on, im using the ls9r clutch. The tune is conservative as I have been using this as a street tune and did not have alot of time to tune at the track. I was only able to get a few passes in. There is still definately more left in it. car is on stock rims full weight full tank of gas
I saw it looked like it bogged a bit coming out of the hole.
What do you think of that clutch?
Nice run!
What mods? The 1/8 seems a bit slow but the MPH is there. Whats going on with the 60'? A lot of spin?
Probably those stock rims. You need to get yourself some 17's. Sounded mean and the MPH is there for a good 10.3 Nice work.
on this pass it started to spin had to slip the clutch a little an she hooked..on these tires an rims that about all I can get on the 60..mybe 1.59....also yes the mph is low should be 137 or so..was running efi live and for whatever reason when I go from first to 2nd shift the shock of the shift is senting a false knock and it's pulling some timming.you can here it come back to life about 5500 in secend if you turn up the sound hard to hear put you can feel it...only does it on the first to 2nd shift...and it wont do it on the street. just under heavy hooking. I will be running it alot over the next few months ill get it there soon
Awesome! Yeah it sounded like you did really well at managing the spin. 137? Nice... Very low 10 then. Possibly a high 9 with a low 60'. You got your work cut out for you though on the 1/8.
What kind of mods are you running? It sounds really mean.
Look forward to seeing more! This is the reason I come here.
