C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] PRC LS7 heads: Pushrod length?
Old 01-26-2013, 10:44 AM
WhiteDiamond
WhiteDiamond's Avatar
St. Jude Donor '15
Default PRC LS7 heads: Pushrod length?
For the few in here that have done the PRC LS7 heads on their LS7, can you comment on what pushrod length you ended up with? Stock is 7.8", I believe, and I have heard 7.750 from a few for the PRCs.
Old 01-26-2013, 11:15 AM
Michael_D
Michael_D's Avatar
I would advise against asking others what they use and check it youself. Then order the correct length to get your desired pre-load.
Old 01-26-2013, 12:12 PM
LS9Drew
LS9Drew's Avatar
Using the stock cam I used the stockers. But I would wait and measure to make sure what exactly u need
Old 01-26-2013, 12:16 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Measure.
I'm running 7.8125" on stock unmilled PRC 285ccs with a comp cam.
If they are milled you will need shorter. If they are unmilled it will probably be close or a bit longer than stock.
Old 01-26-2013, 02:42 PM
WhiteDiamond
St. Jude Donor '15
I plan to measure(or may have them installed at a shop and they will), but I was just trying to get a feel for the reality of having to wait for custom length pushrods(longer install time) versus being able to bolt on and go. Looks like I need to figure a few extra days to get the right pushrods.
Old 01-27-2013, 07:01 AM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,087 Likes on 573 Posts
I bought the Comp Cams pushrod length checker and measured the required length for my 0.030" milled PRC 265s. I came up with a 7.75" long pushrod requirement. This length provided me with the Katech specified optimum lifter preload, 0.070". The stock length pushrod almost completely compressed the lifter (waaaaay too much preload).
Old 01-28-2013, 12:57 PM
Ben01C5
Ben01C5's Avatar
Undy, What cam are you running?
Old 01-28-2013, 02:30 PM
08VRZ06
08VRZ06's Avatar
Cruise-In X Veteran
When I had WCCH do my heads and milled them .030 I used the comp cams push rod checking tool and with the CHE rockers and the cam lobes set to base circle I got .070 - .080 with the stock push rods....
Mark
Old 01-28-2013, 04:05 PM
Undy
Undy's Avatar
Katech torquer 110
Old 02-02-2013, 08:16 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Mine shipped with 7.75"
Old 02-02-2013, 11:24 PM
briancb1
briancb1's Avatar
Smith Bro's Pushrods offers a next day turnaround on custom length pushrods, as long as you order by 10am PST.
I needed a 7.760" 3/8" .120 3 piece pushrod to get the .060" preload I was aiming for... called at 9 am, got them overnighted and the car was on the dyno the next morning.
Old 02-02-2013, 11:53 PM
LoneStarFRC
That's some fast service right there.
Old 02-03-2013, 03:57 AM
briancb1
briancb1's Avatar
OP: If you need 7.800" pushrods, PM me as I have a set of 3/8" .120" wall Manton's I'm selling.
Old 02-03-2013, 09:52 AM
WhiteDiamond
St. Jude Donor '15
I was thinking about having mine shipped with that length as well, but I think I am going to measure and just order once.
PS: Your Avatar scars me.........
Old 02-03-2013, 12:31 PM
2k Cobra
2k Cobra's Avatar
Old 02-03-2013, 04:30 PM
LoneStarFRC
Smart move. That's what I would do too.
And me as well.
To PRC LS7 heads: Pushrod length?
Quick Reply: [Z06] PRC LS7 heads: Pushrod length?
