Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-23-2013, 03:29 PM   #1
rustybridges05
CF Member
Default 1/8th mile
I'm heading out to the local 8th mile strip on Sunday to see what my z can accomplish. I am wondering if there are any launching techniques or any issues launching the IRS I should know about. Ill be on 19 inch nitto drag radials...some people have me worried about hard launches on the IRS ?
Mods are full exhaust, vararam, tune and short throw. Putting down 512/488
Any help is appreciated!
rustybridges05 is offline   Reply With Quote
Old 01-23-2013, 04:43 PM   #2
z0sicktanner
CF Senior Member
z0sicktanner's Avatar
Make sure to do a good burn out on those tires...I run the nt05r 345-30-19 not a big fan of the tire not much sidewall I will be changing them soon...best 60 I cut was 1.67...the IRS is strong the half shafts are the weak link. replace them with c5 half shafts an you will be good to go
z0sicktanner is offline   Reply With Quote
Old 01-23-2013, 04:52 PM   #3
KLRBEE2
CF Senior Member
KLRBEE2's Avatar
I'd keep the half shafts as the weakest link...they are cheaper; especially when you compare them to tires, trans, and differential. You should be able to hit low 7's at 100mph. Good luck! Go to rangeracceleration.com for techniques...good stuff!
KLRBEE2 is offline   Reply With Quote
Old 01-23-2013, 05:18 PM   #4
rustybridges05
CF Member
Quote:
So should I be worried about breaking them my first time out? And yes, I have the exact same nittos.
Old 01-23-2013, 06:47 PM   #5
z0sicktanner
CF Senior Member
you should be fine just take it easy the first few passes..get a feel for track prep..
Old 01-23-2013, 07:09 PM   #6
rattt g
CF Senior Member
rattt g's Avatar
if it starts to wheel hop, GET OFF THE GAS FAST
rattt g is offline   Reply With Quote
Old 01-23-2013, 08:42 PM   #7
azZ06Mike
CF Senior Member
St. Jude Donor '11
azZ06Mike's Avatar
Your tires will limit you if you are stock. For example i run C5 Z06 front 17'' rims on the back of my Z06 with H/C and it is plenty of tire.
You will want to slip the clutch the first 6-10 feet before going full throttle. If the track is prepped you need to try a few times as you will probably bog the motor with such a large amount of tire.
azZ06Mike is offline   Reply With Quote
Old 01-24-2013, 08:55 AM   #8
EvilZ51
CF Senior Member
He's spot on.
I had a set of 345/30/19 NT05R's and for a stockish car they are just to much tire. They are perfect for the street though.
If you want to get serious I would go with 275/40/17 or 315/35/17. As far as breaking anything i wouldn't be to concerned, just watch out for wheel hop.
EvilZ51 is offline   Reply With Quote
Reload this Page 1/8th mile
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
