C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] MSD Atomic AirForce LS7 Intakes Now Available!
Old 03-18-2015, 06:45 PM
Jason 98 TA
Premium Supporting Vendor
Jason 98 TA's Avatar
Default MSD Atomic AirForce LS7 Intakes Now Available!
http://www.texas-speed.com/p-4570-ms...-manifold.aspx
I'm proud to announce the first batch of Atomic LS7 intake manifolds are shipping to vendors! We have 14 still available that will arrive next week! If you want your name on one give us a call or order online! Then following week another 25 will be available!!
From MSD:
When you’re serious about power for your LS7 engine, call in the AirForce! The all-new MSD Atomic AirForce intake manifold delivers improved airflow and distribution to improve the performance of stock and modified engines.
The unique bell-mouthed runner entrances maximize airflow and minimize shrouding - all while optimizing the available plenum volume for an unobstructed flow path over opposing runners. The polymer molded 2-piece design allows for easy access to the runners for porting.
Atomic AirForce accepts an OEM or 103mm throttle body as well as stock or aftermarket fuel rails including MSD’s Atomic LS EFI system. The intake bolts on and is supplied with new gaskets and hardware for a direct bolt-on package.
Old 03-18-2015, 07:24 PM
soldier4life
soldier4life's Avatar
Is it safe to say that the other aftermarket intake they claim more power over is the FAST 102?
Old 03-18-2015, 08:17 PM
SuperchargedTundra
SuperchargedTundra's Avatar
Waiting on dyno #s before I pull the trigger
Old 03-18-2015, 08:25 PM
RedZ4me
RedZ4me's Avatar
me too
Old 03-18-2015, 08:58 PM
jitsu10
jitsu10's Avatar
me 3
Old 03-18-2015, 09:18 PM
[Cerberus]
[Cerberus]'s Avatar
It better make gobs of power for how ugly it looks.
Old 03-18-2015, 09:40 PM
soldier4life
Once it's real world tested and proves to be better I'm buying one. FAST looks better, but this one isn't that bad. Definitely gotta shave down the red MSD's.
Old 03-19-2015, 09:48 AM
Jason 98 TA
I think results will be coming pretty soon. I just have 14 coming real quick & I know a lot of guys were in a hurry to get one of the first ones.
Lingenfelter and Mast both had great engine dyno results from it
Old 03-19-2015, 10:45 AM
starchedup
starchedup's Avatar
Default Finally....
I want to see real life numbers so me4 but DEFINATELY going to sand those cheesy marketing logos OFF. They should fire the person who designed the logs. Definitely a throw back to the Top Gun font/ look. I don't know a single person who likes the logo.
Old 03-19-2015, 11:43 AM
Josh B.
Josh B.'s Avatar
Agreed. Those logos are worse than cancer, and possibly worse than the C7 rear end.
Old 03-19-2015, 11:54 AM
Da Z06
Da Z06's Avatar
Not sure if they are that bad brother!
Looking forward to the performance of this intake!!
Old 03-19-2015, 12:35 PM
RedZ4me
RedZ4me's Avatar
I think it's a decent looking intake...........the red matches the car but waiting for numbers
Old 03-19-2015, 02:28 PM
starchedup
starchedup's Avatar
Its hard work to be uglier than those C7 Taillights. FIRE THAT TAILLIGHT DESIGNER TOO!
Old 03-19-2015, 02:43 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Maybe they did...and he landed a job at MSD?
shane p
shane p's Avatar
For sure grind the AIR FORCE off. like said above fire that person then maybe that would
start a trend and fast could fire some of the stupid lazy rejects they have on their payroll
Old 03-19-2015, 03:26 PM
TRSCobra
TRSCobra's Avatar
While I don't like the looks of the red logos, I think this intake with the red FRC's will look better than the gray FAST intake does. Talk about out of place in the engine compartment! Looks like you left something in primer...
Old 03-19-2015, 03:53 PM
soldier4life
Definitely a plus is it uses factory fuel lines. No need to spend extra like I would have to going with a FAST intake.
To MSD Atomic AirForce LS7 Intakes Now Available!
Old 03-19-2015, 04:06 PM
NHRA95
NHRA95's Avatar
Old 03-19-2015, 05:24 PM
CNB
CNB's Avatar
Do you have the LS3 version in stock?
Old 03-20-2015, 09:13 AM
Chance575
Chance575's Avatar
like everyone else..........need numbers
Quick Reply: [Z06] MSD Atomic AirForce LS7 Intakes Now Available!
