Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Z06 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-08-2013, 11:09 AM   #1
knockout_tx
CF Member
knockout_tx's Avatar
Mike Anderson
Send a message via Yahoo to knockout_tx
Default Heads and big cam....RWHP???( Video on Last page)
I own a 2009 Z06 and just finished heads and big cam. It should be Dynoed tomorrowed, and I was wondering what should the norm be.
I have 102 fast air, 102 throttle body, BB long tubes, no Cats, BB exhuast, and a cold air system.
knockout_tx is offline   Reply With Quote
Old 01-08-2013, 11:15 AM   #2
avenger88
CF Senior Member
avenger88's Avatar
What are the cam specs?
What kinda heads & compression?
Which cold air intake?
Pump or race gas?
With a big street-able cam on 93 I'd say between 600-610rwhp is tops. The norm with a moderate - big cam and all other mods is 580-590rwhp
avenger88 is offline   Reply With Quote
Old 01-08-2013, 12:02 PM   #3
knockout_tx
CF Member
Mike Anderson
Cam is Comp 246/259 624 116
Basically a 293lrrComp cam with more LSA
K&N Cold air
Heads has been reworked, ported & polished
Pump gas
Checking on compression
Old 01-08-2013, 12:05 PM   #4
Unreal
CF Senior Member
Unreal's Avatar
Send a message via AIM to Unreal
560-610rwhp. Depends on dyno, tuning, etc. Should run good.
Unreal is offline   Reply With Quote
Old 01-08-2013, 12:09 PM   #5
z0sicktanner
CF Senior Member
z0sicktanner's Avatar
Quote:
z0sicktanner is offline   Reply With Quote
Old 01-08-2013, 12:12 PM   #6
briancb1
CF Senior Member
briancb1's Avatar
Hard to say but probably 580+ id say.
What dyno? What shop?
Check your PM's
briancb1 is offline   Reply With Quote
Old 01-08-2013, 12:48 PM   #7
avenger88
CF Senior Member
avenger88's Avatar
I'd say low to mid 580ish rwhp . You should really look into a halltech intake, the k&n is one of the more restrictive on the market. A halltech / beehive would be good for another 10- possibly 15hp
Old 01-08-2013, 12:50 PM   #8
avenger88
CF Senior Member
avenger88's Avatar
Also the headers are 1 7/8 right?
Old 01-08-2013, 12:51 PM   #9
knockout_tx
CF Member
Mike Anderson
Z is at Jtran in Houston Texas( damn rain won't stop)and he has just started the tuning.
He has a Mustang Dyno so I am not sure it going to convert to Dyno Jet numbers.
The 2nd feel out run was 585 RWHP and 535 Tq
No hard pulls yet.
Old 01-08-2013, 12:57 PM   #10
wolf8218
CF Senior Member
No hard pulls yet.
I would get a second dyno opinion if I were you. I have had my 350z dyno'ed 5+ times, the only time it was off about 30 hp (read way too high) was at Jtran. This was in December 2012.
wolf8218 is offline   Reply With Quote
Old 01-08-2013, 12:58 PM   #11
knockout_tx
CF Member
Mike Anderson
Do you think that there would be that big a difference??????
Old 01-08-2013, 01:01 PM   #12
knockout_tx
CF Member
Mike Anderson
Wow that is way off....did you say anything to them?????
I did my G37s there and thought the number were good.
Old 01-08-2013, 01:05 PM   #13
knockout_tx
CF Member
Mike Anderson
Yes that is correct.
Old 01-08-2013, 01:08 PM   #14
wolf8218
CF Senior Member
I didn't say anything because on the my350z.com forums they are very respected for some reason (even though they are less than two years old). I knew I would get blacklisted if I spoke up.
My car is basically stock with an intake plenum, JWT popcharger, and underdrive pulleys. The curve that they gave me is totally off from what a normal VQ35DE curve should be. I can send you a scan of the first dyno run (before I complained about the accuracy). Then they showed me a second dyno run that looked normal, but I suspect that was from another car since they never bothered emailing me that sheet. I smell BS in that shop.
Old 01-08-2013, 01:16 PM   #15
FRChilln
CF Senior Member
FRChilln's Avatar
On a Mustang dyno I'm going with 562whp
FRChilln is offline   Reply With Quote
Old 01-08-2013, 01:29 PM   #16
knockout_tx
CF Member
Mike Anderson
My friend did his Corvette at a Dyno jet shop and then went there and he made less RWHP.....and we are talking about a Procharger setup.
My Fin makes 300 RWHP on a tuff Dyno jet i used for my Cobra and lightning.
I like the shop and all the new people there, a nice professional atmosphere, They may have gone through some growing pains in the beginning, but I feel they have turned the corner now,and I see nothing but good in the future. However I will double check all my stuff, and thank you for your input.
Old 01-08-2013, 01:36 PM   #17
knockout_tx
CF Member
Mike Anderson
Default Numbers are looking GooooD
We are at 592 Rwhp now
Old 01-08-2013, 02:09 PM   #18
avenger88
CF Senior Member
avenger88's Avatar
wow greta numbers so far!! . . on a smaller cam'd ls7 with stock heads and intake going from a k&n to a halltech picked up 10rwhp with no other mods/tuning. Id imagine on your combo it would be good for at least that. . .If your knocking on 600rw i wouldn't even bother thou, your numbers are great as is. What kinda torque are we talking so far?
Old 01-08-2013, 03:20 PM   #19
justinlamanna
CF Senior Member
justinlamanna's Avatar
FJ Performance Inc
are they giving your results in STD or SAE ?
justinlamanna is offline   Reply With Quote
Old 01-08-2013, 03:24 PM   #20
tigertank
CF Senior Member
tigertank's Avatar
jtran?
tigertank is offline   Reply With Quote
Reload this Page Heads and big cam....RWHP???
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
