C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Oil Life Monitor
Old 01-05-2013, 01:30 PM
Kennyscott
Kennyscott's Avatar
Default Oil Life Monitor
I have a 06 Z06. I recently took the car to the dealer and replaced a ECM module various sensors as I had a check engine light reocurring. When I picked up the car I noticed the oil life monitor was showing 15%down from 85%. I have only 1100 miles on this oil change. Apparently during the process of installing the ECM module and resetting the various codes in the electronics this caused the oil life monitor to change. I know they started the car many times for code resetting and check out. What to do... do I reset and do the oil change at 30% or just do oil change and reset like normal.
KS
Old 01-05-2013, 01:57 PM
dmuellenberg
dmuellenberg's Avatar
Since you know how many miles since the last oil change, I would change the oil based on miles at around 4,000 miles (or 3,000 if you are more comfortable with that) rather than go by the monitor. No need to do an oil change now. Then you can reset the monitor and go by that for the next oil change.
Old 01-05-2013, 02:06 PM
GMuffley
GMuffley's Avatar
Reset; you probably used about 10% after 1100 miles.
Old 01-05-2013, 02:57 PM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,491 Likes on 2,589 Posts
I change my oil at 50% on the DIC and that is usually near 5000 miles, including a few events. Oil tests show much oil life left even then.
To Oil Life Monitor
Quick Reply: [Z06] Oil Life Monitor
