C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] My DIY LS7 Headswap
Old 12-08-2012, 10:16 AM
vertC6
Support Corvetteforum!
vertC6's Avatar
Do you use 1500 grit dry? I wonder if using a little WD with it would help. I guess you could pack some clean towels in the cylinder while cleaning. Thanks for the tips!
Old 12-08-2012, 10:26 AM
jeffreystar
jeffreystar's Avatar
I always do this dry yes and I do not pack the cylinders with anything during the procedure. I have a Wet/Dry vac going and pulling vacuum about 5mm away from where I am working at all times and is what I suggest.
That being said my DIY is mine, another technique getting the DECK clean is great the point is to get the DECK clean as possible. If that is happening via another way that is just as well.
Old 12-08-2012, 10:46 AM
mistermog
mistermog's Avatar
Originally Posted by Dirty Howie
STICKY !!!!
DH
^ what he said!
Fantastic write up!
Old 12-08-2012, 11:02 AM
LT5 John
LT5 John's Avatar
What about the piston top's?...Did you clean them?, if so, with what??
Great write up...oustanding...
Old 12-08-2012, 12:48 PM
Pb82 Ronin
Pb82 Ronin's Avatar
I always use a dremel with a soft wire wheel on the head surface of the block. Makes cleaning the surface about a ten minute job. Key to compressed air is covering what ever stuff can get into with tape or rags. Keep in mind that most things that get into the chamber that ARE NOT metal in nature will be instantaneously vaporized on start up and kicked out the exhaust. So yes, it's okay to be meticulous, but cleaning cylinders with that level of precision is overkill. Also, I would recommend changing the oil BEFORE the first start up. You will always have a bit of coolant reach the pan past the rings...no reason to have that in the pan on a fresh motor.
Cheers,
Smoke
Old 12-08-2012, 02:40 PM
Mr. Gizmo
Mr. Gizmo's Avatar
incredible post. great detail. make it a sticky. I am exhausted after reading the post. Time to grab a frosty cold one and relax.
Old 12-08-2012, 10:34 PM
jsilvz
jsilvz's Avatar
WOW Jeff
That took some time
Old 12-09-2012, 03:20 AM
sublime1996525
sublime1996525's Avatar
Thank you sir
Old 12-10-2012, 09:32 AM
jeffreystar
I removed 80% of the crud with a plastic scraper and a vacuum, but I did not have the time to spend to get them spotless. I'm sure there is a benefit but I don't know what that benefit is beyond theoretical.
Old 12-10-2012, 09:33 AM
jeffreystar
Originally Posted by 1964vett
Great write up im sure forum will be using this for years to come
HOW LONG DID IT TAKE FROM START TO FINISH?
3 hours on Friday night
6 hours on Saturday
6 hours on Sunday
9 hours, give or take.
Old 12-10-2012, 09:45 AM
GotMoJo
GotMoJo's Avatar
Great job on the write-up! I bet the write-up itself took some time.
This should be a sticky!
Old 12-10-2012, 09:46 AM
jeffreystar
LOL, probably 6 hours itself.
Old 12-13-2012, 09:10 AM
  #33
Screaminr1
Screaminr1's Avatar
Kudos for taking the time to post this. I have done many head and engine swaps and last thing I want to do is spend 6 hours on a computer talking about it. Very cool of you and nice write up. Pretty much the way I do it except I'm not a fan of putting GM torque to yield bolts back in. I reccommend the ARP bolts instead. Negligible cost difference and although you hope you never take the heads off again, you never know. Ofcourse I'm not saying head studs like I'm doing on my current build (over kill), just ARP bolts. Just my .02.
Old 12-13-2012, 10:20 AM
  #34
jeffreystar
Not bad advice at all and actually, if the heads come off every again on this motor ARP bolts would have paid for themselves. The thought was the heads shouldn't have to come off this motor again considering my power goals with this car. Now my Buick LC2 Turbo motor has ARP headstuds and that is because...you guessed it that motor could pop a headgasket at any moment because I'm asking it to make 800+ HP with 3.8 liters. Even though it is on E85 car..
Old 12-13-2012, 12:12 PM
  #35
adamgl
adamgl's Avatar
Thank you for the writeup. Gonna need it this winter.
Old 12-16-2012, 12:38 PM
  #36
JwT
JwT's Avatar
Great write up. I'm getting ready to install my PRC 265 heads. Can someone tell me where I can find a J45059 angle meter?
Old 12-16-2012, 12:56 PM
  #37
LT5 John
LT5 John's Avatar
Check out ARP studs & bolts...Part #234-4317...Don't think you will need an angle meter for head studs...
...type in 234-4317 for part # on there web site...
To My DIY LS7 Headswap
Old 12-16-2012, 05:03 PM
  #38
JwT
JwT's Avatar
Ok so someone educate me here. I'm old school chevrolet where we just torqued the heads to 65ftbs for aluminum heads. But what I'm reading here is the heads are torqued to 22 ftbs, untorqued one turn then retoqued to 22 twice once at 90 degrees and the other at 70 degrees? I need some splaning here....
Old 12-16-2012, 05:12 PM
  #39
LT5 John
LT5 John's Avatar
That's for stock GM head bolt torque/ angle sequence...There is another option. ARP studs or head bolts...ARP studs or bolts, a torque/angle meter is not requred...Total torque is 3 passes up to 80 ft pounds on M11 bolt and 3 passes on M8 up to 25 ft lbs. That's with ARP...GM stock oem bolts require 3 passes and a torque /angle meter is requred...Go to ARP web site, plug in the part number I posted above and read up on them...
Old 12-16-2012, 05:14 PM
  #40
JwT
JwT's Avatar
That's for stock GM head bolt torque/ angle sequence...There is another option. ARP studs or head bolts...ARP studs or bolts, a torque meter is not requred...Total torque is 3 passes up to 80 ft pounds on M11 bolt ans 3 passes up to 25 ft lbs. That's with ARP...GM stock oem bolts requre 3 passes and a torque /angle meter is requred...Go to ARP web site, plug in the part number I posted above and read up on them...
Thanks I got it. Looks like ARP studs is the way to go.
Quick Reply: [Z06] My DIY LS7 Headswap
