C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Where does your clutch release? (2008)
Old 11-12-2012, 07:14 PM
NHRA95
NHRA95's Avatar
Default Where does your clutch release? (2008)
Would like to hear from 08 Z06 owners, and where their clutch pedal releases. Mine releases high. I drove a friends 2010 Z06 and his releases low, much lower then mine. Is this normal? I believe mine has always released high,
Old 11-12-2012, 07:55 PM
dp201
dp201's Avatar
My 08Z releases high also. I was a little alarmed at first thinking that maybe it was worn in spite of having only 6500 miles when I bought it. It seems to release within an inch or two of taking out the slack but I've never noticed any actual slippage when launching or shifting. Hopefully this is normal for an 08.
Old 11-12-2012, 08:00 PM
WhiteDiamond
WhiteDiamond's Avatar
St. Jude Donor '15
It isn't an 08, but my 07 releases very high. Almost right off, maybe 1/8" of take up before it releases..maybe. I don't like it.
Old 11-12-2012, 08:26 PM
GMuffley
GMuffley's Avatar
My 07 releases high as well.
Old 11-12-2012, 08:31 PM
NHRA95
NHRA95's Avatar
I have another friend who has a 09 and another who just got a 2013, Both release low, not high like my 08. And I have less than 3K on it. Never raced.
I took it back to the dealer, and the corvette mechanic told me it was not normal, and something was wrong with the pressure plate. Before I have them ripping apart my car, I thought I'd post here and get your opinions.
Old 11-12-2012, 08:32 PM
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,677 Likes on 1,069 Posts
High. Since I have an aftermarket clutch, if I let it sit for a while, it will "sink" a bit where I need to stick the toe of my foot under it and pull it back up. If I don't, it will engage low. Since the return spring popped off, though, it hasn't "sunk" lately, so it always engage high now.
Old 11-12-2012, 08:50 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
My 08 has always been high.
Old 11-12-2012, 09:53 PM
RWE 427
RWE 427's Avatar
Brand new LSX9R clutch which releases very high.
Old 11-12-2012, 11:24 PM
Dirty Howie
Dirty Howie's Avatar
HIGH !!!
Has 114K miles on it.
DH
Old 11-13-2012, 11:21 AM
NHRA95
NHRA95's Avatar
So, 06-08 release high, and 09 and up release low?
Is that correct? I'm concerned, because the corvette tech that I spoke with said it's not normal. So, I'm still a bit confused!!!!
Old 11-13-2012, 03:55 PM
AzDave47
AzDave47's Avatar
Received 4,507 Likes on 2,598 Posts
my stock 09 releases about an inch off the floor, or a little more - low. The engagement is very smooth and I like the TR6060 which does have a little gear nibble when cold, but that goes away quickly.
I use the Ranger method to keep the clutch fluid clean (for the last 14K miles).
Old 11-13-2012, 04:27 PM
50 4Ever
Wil Cooksey #256
50 4Ever's Avatar
My 08 releases high. Have over 58,000 miles and a few track days. Has always released high.
Old 11-13-2012, 07:56 PM
b4i4getit
b4i4getit's Avatar
When you say "releases high" do you really mean "engages high" almost at the top of its travel ? The more I read your post the more confused I am.
Old 11-13-2012, 08:20 PM
chasboland
chasboland's Avatar
I was thinking the same thing. My thought was engaging not releasing.
Old 11-13-2012, 08:28 PM
IAIA
IAIA's Avatar
My 06 releases AND engages within about an inch or so of each other, so not sure what the difference is in the two terms. Mine is high. Maybe about a third of the way down. ~2-3 inches. 10K miles.
Old 11-13-2012, 08:43 PM
NHRA95
NHRA95's Avatar
When you say "releases high" do you really mean "engages high" almost at the top of its travel ? .
YES, It engages close to the top of its travel. I took it back to the dealership, and was told by the corvette tech it was not normal, and that something was wrong the the pressure plate.
Old 11-14-2012, 09:50 AM
Chevy Cust Svc
Chevy Cust Svc's Avatar
NHRA95,
Please keep me updated on what you hear from your dealership?
Evan, Chevrolet Customer Service
To Where does your clutch release? (2008)
Old 11-14-2012, 01:51 PM
NHRA95
NHRA95's Avatar
Originally Posted by Chevy Cust Svc
NHRA95,
Evan,
I went to another dealership this morning to confirm that I do have a clutch/pressure plate problem. It was confirmed, and it's at the dealership.
Possibly will be ready tomorrow, that's if they have all the parts.
Thanks!
Bob
Old 11-14-2012, 05:22 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
52k miles....street car.
I would say roughly middle. It isn't right off the floor that is for sure.
Old 11-14-2012, 08:57 PM
rapidroy
rapidroy's Avatar
2008, 16k miles, street use only - takes hold towards the top. I was told by a Corvette speed shop that did an alignment for me that it was the highest he had ever felt a Z06 engage, and that it supposedly meant the clutch was nearly worn out and due for replacement.
Yet I have read on here of guys getting over 60-80k miles with a factory clutch....
Mine holds full power in 1st and 6500 rpm shifts to 2nd and 3rd. I've been doing the Ranger method for over a year.
Pls keep us advided what the dealer finds.
Quick Reply: [Z06] Where does your clutch release? (2008)
