[Z06] Halltech ULZ700 components now available
Supporting Vendor
St. Jude Donor '09
Halltech 4.19 lbs/hp Z06 has many lightweight components developed by Halltech and Katech Performance. Here is a list of components and we are now selling these parts on our website. If the component has not been tested by Halltech on the street and at the track, it does not make the list. It is a partial list at this point, but each day we will add parts that we can make available to the forum. The Katech Motor is an E85 build with a mild cam only and high compression for E85. I will have Jason put together a price for one built to our spec.
LINK TO COMPONENTS
Halltech ULZ700
4.19lbs/hp 2764lbs/660 HP
E85 fuel exclusively
Katech Torquer Cam 116
Katech 13:1 Pistons with DLC wrist pins (4.130" 429 cid)
Katech hot honed case
Katech Carbon Fiber valve covers, Coil relocation kit
ARP Chrome Moly head studs and case studs, Titanium bolts and nuts throughout engine
Katech Rod (stock titanium) modification to the small end, H11 rod bolts
Katech High Performance Oil Pump
Katech Billet Aluminum Tensioner w/ titanium bolts.
C5R Heavy Duty cam chain
Katech Oil Squirters to the piston bottoms for cooling
FAST LSXR Intake (no porting) Katech Paint matched
WP 102 Billet Throttle Body /Halltech HNW102 Silicone Conn hose
Halltech Super Bee™ CF112/w Halltech Super Beehive™
Beehive PSI springs and Katech Titanium Retainers
HP lifters
ZR1 Carbon Ceramic Brakes/w StealthTitanium caliper mounting bolts & bleed screws
Ultraleggera 19" front wheels/20" rears with 285 Michelin Pilot Sport Cup/335 rears
Pfadt Carbon Fiber driveshaft
Pfadt Coil Over Suspension/Race Anti-sway bars
Pfadt Engine and Transmission Mounts
ATI underdrive crank balancer w/ ARP bolt
Caravaggio Race Seats/D Steering Wheel
Aluminum honeycomb Tunnel Plate with titanium screws
StealthTitanium lug nuts/hood hardware
Titanium seat mounting bolts, alternator bolts, headers bolts, steering rack bolts and nuts, belt tensioner bolts, rear deck bolts and nuts
Kooks Headers mated to Akrapovic Titanium Xpipe and mufflers
Halltech ULZ Carbon exhaust tips designed for the AK EVO exhaust
EmailTune® tune by Jim Hall
Onboard E85 Wideband Dual O2 sensors
65lb/hr FAST injectors
FAST Billet Fuel Rails/Earls plumbing
Stock radiator w/160 thermostat
Iridium Plugs
Katech Aero kit, Carbon Fiber front rotor cooling ducting, Halltech titanium FasciaLift kit
Halltech Carbon Fiber Hive Port™ with full ram air modification
ZR1 Rear Spoiler-Paint matched
Halltech Carbon Fiber Roof and pillar
Katech Carbon Fiber Deck Lid w/ Lexan rear window
Halltech GT2 Carbon Fiber Direct Radiator Exit Ducting Hood
Halltech Carbon Fender Ducts, Rear Carbon Brake Ducts, Carbon Gurney Flaps, Carbon A-pillars
Torco Synthetic 5W40 SR5 Racing Oil with liquid molybdenum
Braille 340R Lithium Ion Battery (4 years old now) 9lbs.
OS Giken Triple Clutch, Tick Master Cylinder, Tilton Slave with Katech upgrade
Halltech Carbon Revolution One Piece carbon fiber wheels
LINK TO COMPONENTS
Halltech ULZ700
HP lifters
Iridium Plugs
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
