C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Do you guys think this is something that can give me a peace of mind?
Old 12-06-2012, 11:27 AM
HyperX
HyperX's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
Default Do you guys think this is something that can give me a peace of mind?
Since my warranty is up, I want a mod to allow me to have a peace of mind with the ls7 dropped valve issue. I am looking at comments before I pull the trigger on this:
PRC LS7 CNC Ported Cylinder Heads w/Freight *Exchange basis* 8 199-161SS 1.61-Inch Stainless Steel Exhaust Valve,
Precision Race Component EHT .650" Spring Kit
LS7 Head Gasket, Z06 427 Head Gasket, 4.150 gasket bore
ARP LS1 Hex Head Bolt Kit, 2004 & up LS1/LS6/LS2
GM LS7 Header / Exhaust Gasket
Remove Heads, Trasnfer Intake Valves, Replace Exhaust Valves w/1 piece, Install Spring Kit
Speed Inc. LS7 custom cam Intake lobe 13017R 227@.050 .613 lift Exhaust lobe 13021R 243@.050 .623 lift LSA 115.5
Camshaft installation gaskets
-GM Water pump gaskets (2) 12630223
-GM Balancer bolt LS1/2/6 12557840 -GM crank seal 12585673
NGK Copper Spark plugs set of 8 Installation Camshaft
Tune
Old 12-06-2012, 02:17 PM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
Looks good. What other mods do you have? Should be solid 550rwhp car or more with a decent header/intake setup.
Old 12-06-2012, 02:44 PM
HyperX
HyperX's Avatar
I am 100% stock except for mild to wild switch (which I dont even consider a mod).
I will get an intake setup, but leaving headers stock. I had an issue with drone with my base c6 and like the original exhaust.
I love the fact that I will get extra horses, but I am primarily doing this to have a peace of mind and no surprises. I plan on some long trips in the spring/summer.
Old 12-06-2012, 03:12 PM
2000FRCZ19
2000FRCZ19's Avatar
St. Jude Donor '12
you will need to change out the springs on the heads. that cam on a 1.8 rocker will be around .650 to .660 lift. the heavier valves plus the higher lift of the 1.8 rocker with that cam and you will find trouble at some point.
Old 12-06-2012, 03:42 PM
HyperX
HyperX's Avatar
Thank you
so go with something different than whats in the package
Precision Race Component EHT .650" Spring Kit?
What do you recommend?
Old 12-06-2012, 06:22 PM
2000FRCZ19
2000FRCZ19's Avatar
St. Jude Donor '12
prc has a set good for .700 lift as well as comp. I am running the comps on mine. they are not cheap but it will save you a lot in the long run.
Old 12-06-2012, 06:48 PM
Unreal
Unreal's Avatar
PRC has .675 springs for a few bucks more. Just get those if you are worried. Texas Speed said the .650s would be fine for .650-.660 lift when I talked to them.
Old 12-06-2012, 06:49 PM
Lethal427
Lethal427's Avatar
Good luck, looks killer, should fly!!!
To Do you guys think this is something that can give me a peace of mind?
Quick Reply: [Z06] Do you guys think this is something that can give me a peace of mind?
