[Z06] Cam Specs - Looking to be educated
I just got the cam spec's for the custom Comp cam that's going into my Z06. It's very rare for me to purchase anything that I don't know something about. Can anyone help me understand or break down each spec so I have a better understanding of what it all means
Here are the specs:
Valve lift:
.608 on intake
.615 on exhaust
With duration @ .050
230 intake
246 exhaust
On a 116.0 Lobe Separation
Here are the specs:
Valve lift:
.608 on intake
.615 on exhaust
230 intake
246 exhaust
Duration at .050 is the lobe duration in degrees from the .050" lobe lift points on both sides of the lobe. There was a time when "advertised" duration numbers were given, but there was much discrepancy between manufactures as each one would reference different lift points on the lobe, so you couldn't ever compare cam profiles. The .050" standard was then instituted. A few years later, manufactures started noting advertised duration at .006" lift. I prefer to know the .006" numbers, .050, .100, .200, etc... Knowing all the duration lift points tells me what type of lobe profile the cam has.
Lobe separation is the angle that is represented from the lobe centerline of the intake and exhaust lobes to the center of the camshaft. As LSA tightens, valve overlap increases. Valve overlap is the time in which both the intake and exhaust valve are open during end of the exhaust stroke and beginning of the intake stroke.
Thanks for the reply. Because of my lack of knowledge of cams, just reading up on Comp Cams website explains a few things, but I'm still unclear about how one custom cam differs from another. Meaning, when I look at those spec's, how would I know if its a "mild" cam versus a "aggressive" cam other than what the builder tells me. Not that this is about questioning my builder or any other builder, I just don't understand the numbers I'm looking at.
When someone says or I read a post about making sure to get a cam with "this LSA" or "that lift" to keep it mild mannered, that's what has peaked my interested in the numbers aspect of all of it.
