[Z06] Another dropped exhaust valve, lesson learned, need some ideas
I am the latest victim of the dreaded LS7 exhaust valve drop My car is a 2006, has 29k miles and Intake/Headers/Ported TB/Manifold/Tuned by CMS. The valves were not upgraded at the time, was something I was looking to do down the road when I upgrade the cam but now it looks like I am going to need a new motor. At the time of the incident, I was making a left hand turn onto a busy street, going about 40mph, 2nd gear coasting along and all of a sudden the car got louder, my initial reaction was something with the exhaust came loose, but before I made it to the side of the road, I heard lot's of noise coming from the motor and seconds later a big puff of white smoke.
This is not a thread however to bash the LS7 or GM, but simply a thread to get some ideas from others that have been through this headache situation and what they did to get their car back on the road stronger than ever. My car spent most of it's life in the garage during the week, occasional redline pulls to 7k/spirited driving and participated in two side by side events put together by the guys at Shift-S3ctor.
Any issues with dropping motors even after upgrading the valves? My current plan would be to go with another LS7 with the upgraded heads with a upgraded streetable cam, not sure if I want to port the heads while I'm at it or not? Would I also need a clutch? Any ideas would greatly be appreciated.
We were just talking about this yesterday.
Good luck with the rebuild.
OP sorry about your car this blows good luck with the rebuild
Bummer to hear, this strikes close to home as I've got an 06 with almost 22k miles and soon will get similar mods & tune. I guess I'll invest in a set of heads sooner than I thought.
How many miles on the setup?
Im doing my 06 now , a new block , Calies stroked 440 crank , Manley rods , clevite bearings , Wisco pistons , reworked stock heads with new valve guilds , dual springs , stock titanium intake and inconel exhaust valves
Or you can buy a short block from Katec nicely prepped for around $7-7500 and a set of heads for around $3500 , which is a good deal if you have to buy a block and want to stay with stock displacement .
Taking the heads off and replacing the valve guilds is stupid cheap compared to buying a new motor .
You dont need new heads or valves tho , just new guides installed that fit the valves better
Mine popped sitting at a traffic light
Sorry to hear op........but remember the shop that starts with a K has never seen this.it's the pistons.lol...I got to ask why in the hell would anyone buy from someone that says the valves are not a problem?or that there even is a problem, they've never seen it?...the wrighting has been on the wall for years...it's happing to all ranges of miles stock to modded it doesn't matter..most of the time the car shows know warrning sighs,and will have all of it's power till it blows...untill ppl stand up in numbers this will keep happing, and GM don't give a f*** about you or your car. it's the last gm car I will ever buy.
Dont guess , stop driving the car and have new valve guids put in the heads NOW .
Thanks for the kind words fellas. Would a stock short block be sufficient enough for a street car? I am trying to save as much as I can and at the same time without going half ***. I'd like to go with my old modifications with upgraded exhaust valves and a street cam.
Yes, stock exhaust valves thanks man!
Most likely scenario would be a stock short block, buy the parts on my own and have CMS put it all together for me.
Thanks man! I'll get all that once I start the process
I had about 8k miles on the setup. I'd do this as soon as you can, considering what I just went through.
When I mentioned having the guides measured, I was talking about the guides from the heads on the motor that blew, just to see what they looked like, I should have been more specific.
Stock Short Block would be fine, or get Forged Pistons then leave the rest stock those are the only "weak" part of the stock bottom end which is already good for 650+whp
Cheers, Paul.
