[Z06] 8 exhaust valves out, 8 new ones in PICS
#41
Thanks!
#42
Former Vendor
Speaking of geometry, one of the potential causes that was thrown around was that the guide and seat might not be "lined up" properly - I think it was referred to as valve seat concentricity. If that was off from the factory, does your step of machining the seat correct that? What kind of tolerance is there for that process? Sorry of this is a dumb question, I'm not a machinist.
Thanks!
Thanks!
it's when the guide wears that valve face to valve seat geometry goes awry.
#43
#44
St. Jude Donor '08-'09-'10
Nice work. Just curious but based on this statement, are you inclined to believe this is a stock guide issue with the LS7 or a combination issue with guide and exhaust valve?
#46
Former Vendor
The obvious differences with the LS7, as I'm sure you know, is the implementation of the 1.8:1 ratio rockers arms and rev limiter moved to 7100 RPM. So, at least in my mind, unless there has been a material or tolerance change in the guide/valve combination, the increased rocker ratio or increased red line (or combination thereof) are likely at the root of the issue.
#47
$2,695 ...car will be in the shop for 3-5 working days
Parts Include
CHE Valve Guides
SS exhaust Valves
Dual Springs, ti Retainers, Steel Spring Bases
Stem Seals
Head Bolts
Head Gaskets
Comp Trunnion Kit
Machining & Labor
Install guides and hone to size
Comp Valve Job
Light "bowl porting"
Mill & CC
Clean & Assemble
Upgrade Rocker Arms
R&R Heads
__________________
Parts Include
CHE Valve Guides
SS exhaust Valves
Stem Seals
Head Bolts
Head Gaskets
Comp Trunnion Kit
Machining & Labor
Comp Valve Job
Mill & CC
Clean & Assemble
Upgrade Rocker Arms
R&R Heads
__________________
#48
That's the 64,000 dollar question..up until the LS7 we just didn't see this type of wear - in fact, it was rare to find a guide issue on a LS1, LS2, LS3, etc. - and in the LS6, GM opted for sodium filled exhaust valves.
#49
#54
Thanks.
I'll be doing my heads a week from Friday. When I changed plugs this past weekend, I noticed 6 and 8 were very wet with oil.
88,000 miles on the engine.
I'm convinced there is a geometry problem. You can't get excessive wear unless there is significant side force on the valve stem.
Among other things, I'm going with roller rockers...can't get side loads with rollers.
#55
Curious of any theories on what step they may have screwed up from the factory?
