[Z06] 8 exhaust valves out, 8 new ones in PICS
Former Vendor
yes, typo
what is interesting to me is that guide wear on the rest of the LS family is nearly non-existent.
in this case, it comes close
Former Vendor
Just curious.
Former Vendor
we see 3-4 sets of LS7 heads each month. as the mileage and track use increases so does the guide wear.
we've done over a dozen engines where the exhaust valve head ended up detached from the valve stem. don't know the root cause of the failure but seems logical that the once the valve stem wears and the valve heads starts wobbling around the seat, there is going to be an issue.
we maintain data on all our cylinder heads and engines, yes.
Thanks again for sharing the information. Any other head data you can share would be great of course if you are ok with it..not trying to be pushy.
Former Vendor
$2,695 ...car will be in the shop for 3-5 working days
Parts Include
CHE Valve Guides
SS exhaust Valves
Dual Springs, ti Retainers, Steel Spring Bases
Stem Seals
Head Bolts
Head Gaskets
Comp Trunnion Kit
Machining & Labor
Install guides and hone to size
Comp Valve Job
Light "bowl porting"
Mill & CC
Clean & Assemble
Upgrade Rocker Arms
R&R Heads
__________________
Parts Include
CHE Valve Guides
SS exhaust Valves
Stem Seals
Head Bolts
Head Gaskets
Comp Trunnion Kit
Machining & Labor
Comp Valve Job
Mill & CC
Clean & Assemble
Upgrade Rocker Arms
R&R Heads
__________________
Parts Include
CHE Valve Guides
SS exhaust Valves
Stem Seals
Head Bolts
Head Gaskets
Comp Trunnion Kit
Machining & Labor
Comp Valve Job
Mill & CC
Clean & Assemble
Upgrade Rocker Arms
R&R Heads
__________________
Former Vendor
Very solid package it seems. You got your springs, your trunion upgrade, valve upgrade, and the intake valves taken care of as well as the guides. Plus the bolts and the gaskets, and the other extras. That's a heck of a deal installed.
I know you deal a lot with the road racing guys out there, is this the package that they generally run as far as their cylinder head work?
#33
Former Vendor
yes, same guide/valve combination - but the road race package gets our full CNC work ($550), different valve springs and 65 cc chambers.
#34
#35
Are the valve guides pressed in or cast in place?
#37
Former Vendor
if you do this yourself here's what we do. BTW, other methods work, it's just what we do.
1-remove guides
2-clean heads
3-preheat heads to 255° F
4-dry ice new guides
5-drop in place
6-let heads cool
7-hone guides to size
8-machine seats
#38
This a totally different approach to us than GM has been doing.
#39
Remove guides sounds like an interesting 1st step...Do you heat up the heads first? Do they press out from the rocker arm side of the head?
#40
Former Vendor
they press out from the valve side. we use a pneumatic press that applies force with impact. they press out easily without galling as long as you maintain proper geometry.
