[Z06] Baseline Dyno Pulls Katech Torquer
I just had mine done at Lethal Performance here in San Antonio. I have AR 1 7/8 headers and a FAST intake and I put down 538HP and 509 torque.
Danny and the crew at Lethal are great to work with too!
I sort of put these numbers up wondering what reaction they would get and I did have reservations about putting them up.
This is why I show the entire run file which tells what the A/F ratios are at various RPMs, as opposed to just the graph.
All but one respondent in this thread, immediately recognized that these are the numbers of a cammed car with no prior dyno tuning at all.
But it may dyno more, or it may dyno less when it's all said and done, I don't know at this point, but this is just a starting point so that the tune can be completed, the A/F ratios dialed in and KR eliminated.
This is what it looks like to start.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
Why are people even arguing over chassis dyno numbers? Slap it on another dyno and it will make 20rwhp more or maybe 15rwhp less. They are tuning tools and should not be taken for truth.
When Ricky takes it out to the strip and gets a trap speed, you will all have something to bench race about, but pissing back and forth over rwhp numbers is pointless.
I posted my results for a comparison with stock manifolds. Not too many guys running stock exhaust with a cam. I agree with Richie, all dynos differ and the trap speed will tell the tale. But I don't think Ricky's combo is done yet. A little more fuel with no KR should net at least another 20 hp or so.
Good points, and that is exactly what we are trying to do here and why I had that bung put in today.
You aren't going to believe this, but as I was backing it onto the dyno, it threw a lean code and I had real reservations about going through with the dyno run.
Turns out, the guy who owns the shop, I had met about 10yrs ago when he raced Mustangs.
We decided to have him weld in a bung, before the pulls so that we could watch the A/F ratios as the car was making the pulls. If he saw anything that crazy or that he didn't like, he'd give me the signal and we'd stop the pull.
I cleared the code in my HPT, I was behind the wheel, he operated the dyno, and we did two pulls.
Yes, it was lean.
Is the Fast Intake ported?
At this point, I'm on the stock manifolds, the stock ported intake and waiting to complete the tune.
So yeah, this is about where I should expect it to be at this point.
Quick,
I did understand what you said about the tuning proir to posting. However, I don't suspect the startup tune and data logging will be that far off. I know it is running a bit rich, but some have got those numbers back with their bolt on only car.
Here's to your fully tuned numbers being a lot better.
I have the same cam going in my car. The funny thing is I have seen reports all over the place from this cam.
This one was 541/522 with cam, headers, cai
http://www.youtube.com/watch?v=RNQuKq8xSuc
And this one did 516/458 with only cai and cam tuned on 91oct
http://forums.corvetteforum.com/c6-z...o-results.html
Quick,
But it's actually running lean. It needs fuel at just about every point in the RPM range. Those 13s you see, should be 12.7 12.8
As mentioned before, backing onto the dyno, it threw a lean code which I cleared out in my HPT prior to the dyno pulls and just before we decided to put the bung in.
The street tuning has primarily helped street drivability in addressing any surging, idling or bucking issues. Datalogging the street and highway driving is one thing.
WOT runs to 7K, and tuning for power, just simply became impractical on the street. I was going to complete the WOT data logging at the track this weekend, but just had a nagging feeling that I needed to know what the A/F ratios were before I tracked it (and damn if it didn't throw a lean code backing onto the dyno). That and I knew that I still had a bit of KR and did not want detonation and a broken piston on my first track visit. I had to know.
So that's part of why I went ahead and took it to the dyno.
#33
I am impressed with how much power the car produced considering that was a shakedown run just to see where you are at.
I'd recommend a set of headers. Without them, I don't think you quite get the full heads/cam car experience. The sound, the extra hp/tq, definitely want to consider getting a set.
#34
quick,
You have a solid setup man. Mine was built in my friends driveway and tuned at dallas performance. LG super pro's ported fast intake, ported NW TB made 562/520. DP says it's the hardest pulling vette for the mods it has he's ever tuned. Reworked, hand ported/polished heads, no milling.
#35
Good move on putting the bung in the exhaust collector. It should allow your tuner to get a more accurate AFR than from the exhaust as usually done. It will also allow you to mess around if you get HPTuners. Just be careful if you do this it becomes addicting. I used lo log my car every day on my work commute and upload a new tune every morning
DH
DH
#36
I keep reading about how not to focus on dyno numbers as we dont race dynos and I agree 100%. But now it seems that if we want more than 540rwhp after a hci swap, we will have to conform with an ugly power curve.
I have talked to several shops and they all agree that the ls7 cylinder head is an awesome design and can support way more than 540rwhp when properly worked over with a matching cam and ported stock intake/tb. And no matter what octane we use and without having an all out race car.
I know we all have different purposes for our cars, and we also have different opinions, but are we conforming for 520-540 rwhp when these engines can put out way more than that without sacrificing driveability. I mean, there are people putting out those numbers with just a cam and full exhaust, me for example, 545/490 with 93 oct in Texas and 525/470 with 91 octane in Phoenix. My cam does surge a little @ 1600 rpm but I have convinced myself that I drive a super fast sports car and not a Corolla so small sacrfices have to be made, and I can live with that.
Just wondering if we have been conditioned to believe these numbers are normal or if I've been lied to when I was told I can have a high 500 rwhp car that is streetable?
I should have proof pretty soon.
I mean no disrespect to the OP or anyone else. Just thinking out loud and wanted to share.
#37
To get people talking about something else aside from these damned valve threads, anticipated "statements" from GM mentioned nearly 5 weeks ago, pipe dreams of "unannounced" warranty extensions, legal implications of the whole dropped valve history and scenario, and stick shaking and vow making about never again buying GM products.
It's time to move on. Let's talk about something else. Lets "debate" something else. Like, well, dyno numbers.
I mean we can't argue the automatic vs manual subject in this section, so I figure dyno numbers are just as good.
#38
100% with you!!
Let's get back to how exciting it is to race this car or how fun the weekend drive was or how cool the car looks and sounds.
I know the valve thing is played out and I'm in the mist of having my heads reworked and others should do they same IF THEY want to, if not, jut drive the damn thing and enjoy it.
I hope my previous comments get some feedback.
#39
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Ricky,
Great looking flat torque line that you can place your beer on (very nice).
As you know the true measuring stick will be how she performs (trap speed) at the dragstrip after your final tuning is done.
As you also know you are leaving some decent power on the table until you add your longtube headers into the equation.
Best of luck with your new hotrod Z.
#40
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,091 Likes
Looking forward to your final numbers Ricky! You are going to LOVE it!!!
I'll have my numbers up here soon enough. Katech Torquer 110, Fast 102, NW 102 throttle body, Kooks 1 7/8" headers and Jim Hall's 107R intake/Beehive combo.
