[Z06] How Many Z06 Owners Are Running Solid Stainless Exhaust Valves?
#1061
So from that, I gather that the attitude to be that the spintron is the "be all and end all" when it comes to this matter, and that points such as the one you make above, and actual real world experiences reported by other professionals and shops, enjoying success, somehow don't matter.
Most of your real world experience isn't statistically significant. Not a lot of samples, nowhere near enough operational time, inconsistent setups, and no test plan.
Lastly, there's most likely nothing wrong with many of the SS valved heads that a possible lower rev limit wouldn't cure, but you don't know.
And I am annoyed that Katech decided to stop sharing what they were seeing on their spintron, they were showing us the results of thousands of dollars in testing that I will never get a chance to see now. Everyone gets you had unanswered questions, its just I wish you could have gone about getting answers a different way.
#1062
It's not the be all, but as nitrojunky pointed out there
....And I am annoyed that Katech decided to stop sharing what they were seeing on their spintron, they were showing us the results of thousands of dollars in testing that I will never get a chance to see now. Everyone gets you had unanswered questions, its just I wish you could have gone about getting answers a different way.
I think this is the key point of the argument. There is no doubt in my mind that GM has done more lifecycle testing on these valve trains than probably everyone else combined, and they were willing to back that up with a 100,000 mile 5 year warranty.
Sure solid SS valves are going to be stronger, but they are heavier, and that impacts how high it can rev without loss of valve control....
Also on a side note, with regard to Katech's representative and that thread, I really don't understand the rationale behind blaming me. The whole notion of I'm going to take my ball and go home, and "punish" the rest of y'all, I don't get.
I'm going to withhold information, because I don't like the questions asked????
I don't understand that.
That isn't my fault.
I believe that there have been 26,065 C6 Z06s built.
They built 6,272 2006 Z06s. Did you know that for MY 2006, the power train warranty was only 3/36,000 miles and not 5/100,000 miles?
So if I'm right on that 26,065 number, then about 24% of all Z06s built, did not have a 5yr/100K mile power train warranty on them.
Also, I have no idea as to GM's warranty exposure in this matter. But I do know that they sell a lot of Cobalts, and other vehicles, which likely offset some of whatever liability they would have on the Z06. It should also be considered that a portion of warranty cost is figured into each vehicle they sell.
Also, marketing it as a track capable car, and then not honoring warranty claims were it to suffer failure under the conditions it was marketed for, would of course limit their exposure as well.
So your points about 5/100,000 mile warranties, have to be taken in the context of each of the above.
Furthermore, by the time that announcement on the 2008-2011 models and guide mis machining was made in September of 2012, many, if not most of the Z06s built, would have been out of factory warranty.
Or better put, anything put into service 60 months or more prior to the release of that statement.
Knowing that the first 2008s came out in late 2007, has to be considered as well.
As for the LS6 in the C5 Z06 and it's use of hollow stemmed sodium valves, well, what I would do, is ask a cylinder head professional about the length of the two valves, the fact that the LS7 makes 100 more horses than the LS6, runs at 500RPM higher red line, and about any variations in generated heat between the two engines.
I'd ask if any of these might make a difference when attempting to compare the use of this type valve in each of these respective engines.
You might even have other questions with regard to the differing circumstances between the LS6 and the LS7 and what if any role that plays in what we are seeing.
He might tell you about the mis machining issue, but when/if he does, ask him how that explains the valve drop issue in the 2006 and 2007 models.
They made 8,159 Z06s for 2007
That's a total of 14,431 cars, or better than 50% of production.
Ask him why this matter has shown up in them too, when GM says that it affected 2008-2011 cars.
This is where I get bothered by this, without testing you or your vendors don't know what the valve is doing without testing.
Now for most LS engines which has a 6500 or so rev limit, SS valves are probably the cost effective solution, and they may even do okay on a dyno to 7000 rpm. But until you measure your combination, you don't know.
And we do know from the experience of lots of broken engines, hammering the valves isn't good for them, but if they're strong enough they will take it for a while, but without know what they're doing you can estimate your failure rate, so you know when to redo them prior to dropping a valve.
And that's what your insistence is doing, insisting you know they work, when all you really know is they work for now.
For people whom failure is not an option, they solve the problem by testing until failure enough times until they can get statistics, then they do a maintenance program that services parts prior to failure, or they redesign the solution. In this case, unless you have a setup that someone cared enough about to test (like Comp Cams, Crane, someone who puts together complete kits), but if you change the weigh of the parts they used for their test, you're doing the testing for them.
You start mixing and matching components, you can't be sure what will happen as the rpm goes up.
All of these cylinder head companies out here, continuing to make good on these setups and others............How do you think they made it? Blind luck????
You don't trust anyone to give you the straight answer, and yet you're willing to take the word of someone you're likely to pay multiple thousands to, has experience with fewer cars than GM makes in a day.
That's you're choice, but for others who don't really understand the mechanics of the valve train, or why GM can't/won't produce a list of VIN numbers, someone needs to explain why your answer to the problem doesn't really answer anything either. And there are solutions that you can put your faith in(even if you don't use the factory valves).
I'm not knocking that, as they make great products. But I don't trust much of what they have to say about this matter.
#1063
On the other hand, solid stainless valves with a set of properly machined guides have an excellent track record versus other non-stock options. In making my decision I put the theories aside and took a step back to see whether the weight of the solid valves and dual springs with my stock cam would ACTUALLY have any real world negative effect on my car.
#1064
Well, that's what these guys were doing. And then this happened.
http://forums.corvetteforum.com/c6-z...post1585189286
http://forums.corvetteforum.com/intr...post1585770147
Just me, and no offense, but somehow, I don't think people who are interested in protecting themselves from engine damage, are going to listen to a guy with a fattened hog in a tweed business suit as his avatar, repeating himself about horse hockey when it comes to this matter.
BTW, I don't believe that I've ever seen horses play hockey.
Horse Hockey C'mon, Why not stick with GM or Katech on a build?
Why use" Shadys fix shop" ydns
#1065
I did not feel comfortable putting stock valves back in my heads due to the unconfirmed cause of the failures. This point above is one that deterred me from using the Ferrea semi-hollow valves as an alternative to stock. On the other hand, solid stainless valves with a set of properly machined guides have an excellent track record versus other non-stock options. In making my decision I put the theories aside and took a step back to see whether the weight of the solid valves and dual springs with my stock cam would ACTUALLY have any real world negative effect on my car. With no examples of damage caused by running this setup, an OK from Katech on it's use for a street car and only examples of success, I went with it and don't regret it. If I ever decided to change my cam I would move to a lighter beehive spring because I believe it would only at that point be necessary for a more stable valve train.
If I knew 100% that the guides alone were the cause of failures and the stock valves with properly machined guides would last 100k+ miles then I would have used stock valves. And no, the fact that there are LS7s running around with stock valves that haven't blown up (yet) is not conclusive evidence that there is not an issue with at least *some of the stock valves. With the quality control we see over the heads, I can't have confidence in the exhaust valves being 100% safe.
While I don't believe this thread to be propaganda because there is no harm intended, I do understand the dislike of this thread promoting a head fix option that is one-sided and implies that there is one and only one option to use.
But I'm pretty sure it's OK if anyone out there wants to start their own thread titled "How Many Z06 Owners are Running Non-Stock Non-Solid SS Exhaust Valves?"
Keep your own list and link all the facts you want and all the shops and members who recommend and/or use those other options in their LS7. It would be good for the community to have more options and examples listed for those making decisions. The OP certainly is not working for the shop that many like to imply that he does, but he also is not going to stop his project whether anyone likes it or not so there is really no use discussing it anymore.
I encourage people to talk to the company which begins with a "K" and see what they have to say about this matter.
As well as talk to professionals out there whose opinions and experiences differ from theirs and their test findings.
And then make the best decision which suits them.
#1066
It's almost like every time you say something, ....it's like "he's" talking to us.
So when a hog starts talking about "horse hockey" I just about $#** my pants.
I guess it's this way because for so long, people posted up images of themselves as avatars, and I'm having a time making the disconnect. But every time I read something that you write, and I look over at that hog, I just bust out laughing.
#1067
Of all of the heads that WCCH has done with bronze guides and OEM hollow stem valves, none of those have failed either. So is the guide the fix or the valve the fix? I'll give you hint, its the guide. When you take the mismachined guides out of the equation, these motors don't drop valves - its that simple really!!!!!!!!!!!! To say all these bronze/SS cars running around not failing is the fix completely turns a blind eye to the bronze/OEM valve cars. Oh, and I track, drag, and flog my cars regularly - no internet waxer here.
Now I guess its ok for the SS camp to shut down a thread where a vendor shows data not supporting their cause, and then its ok for that camp to start their own thread advertising for people to jump on their bandwagon. If one is to say they are helping educate people, tell them the facts and show them the data, don't tell them what to think.
I checked them last year and they were loose. Had them put in new bronze guides and springs.
Maybe the guides where on the brink of being bad the whole time on my car?
#1068
I'm sorry buddy, And for a long time, I've gotten a chuckle out of reading your posts, and I really mean no offense here, ......but I just can't get past the image of a hog headed executive making comments on this matter.
But my question, Why pass up GM or Katech and trust Shady
#1069
Combustion temps should be similar, the rpm, cam, geometry changes would all need to be accounted for in lifecycle testing. It's possible that a few % failed before 100,000 miles and they said to ship them anyways, it's possible they all passed.
All of the reading on hollow stem valves does say they don't tolerate guide/seat misalignment, and fail by popping off the valve head. GM, if the identified the exact cause, kept it to themselves, it's a shame, but the lawyers are always circling.
Are you taking into account the fact that people have been building engines and they have been running fine, without the testing you mention?
The further you are from the guys who have the budget and equipment, the further you are from what's really going on, most places don't share the results of testing with customers.
Manufacturers run these kinds of tests, create guide lines on the application of components. Vendors get to consult with most manufacturers, "these springs work for this kind of weight, to about such and such rpm" or they put a kit together and say you can run this to 7200, and the tuner should set the limit to what they feel is prudent. Katech mentioned they set the limiter to a higher value for street use, than a road race engine program would recommend.
When you're planning on selecting a head and cam package, what's your criteria for a successful life span, and what evidence do you accept for proof of that success?
#1070
#1071
Did they give you a rev limit, or just imply you could keep the stock limit?
#1072
Install an EGT gauge in cyl #7. Offhand I'd suppose that you'd want to stay under 1500F, and my counter-intuitive theory is that moderate-heavy load at low RPM may be as or more problematic than WOT.
#1073
Ferrea drilled valves? Unproven, run away!
Ti valves? Guru says unproven, run away!
Sodium valves? Satan's spawn, run away!!!!!!!
Spintron? Snake oil hocus pocus, run away!
Vendor-generated lab tests? Marketing lies, run away!
Engineers? Elitists, run away!
Science, physics? Lies, damn lies, run away! Trust no one with an IQ over 30!
#1074
When I was looking into extended warranties with my prior Corvettes, one of the big warranty vendors in here told me very aptly, "you're buying time, not miles."
He was right.
And that brings me to your prior comments and carries me to answering the final comments in your current post. If I offer you a warranty which is going to run out in 60 months, I can offer you more than 100,000 miles if I know that you will never come close to that.
Time would be on my side, because when 60 months is reached, I am no longer at risk to have to make good on my agreement with you. Many of these cars are sold in the north and northeast, where they are only driven 6 months out of the year. Many are also 2nd, 3rd, 4th or 5th vehicles.
GM, has an idea of how many miles the typical owner, or even the majority of owners, of one of these cars is going to drive it over that 60 month period.
And they know that it is not going to be anywhere near 100,000 miles.
So when they offer 100,000 miles, they expect just the response you see. People say, "well, oh, if they are warrantying it for 100K miles, well then it must be tough as nails".
No. Because they know that at the end of that 60 months, out of 10 owners, very few of them will be anywhere close to 100K miles. So for the average owner, they're warranting it for "60 months".
Or 30-35 months, if that owner is in some of the colder climates where the car is only going to be driven 6 months out of the year.
Cars which have been sitting up over the winter months, are at more risk for electronic issues.
Notice how the warranty on those type things is for but 36 months.
So I don't look at a 5yr/100,000 mile power train warranty in this case as any indicator of durability, so much as I look at it as evidence that GM has carefully looked at all factors which could make them liable to a warranty claim, of which durability is just one.
They are more concerned about "time" than they are miles. And the clock is running from the day that the vehicle goes into service.
On a side note, the average person who can afford one of these cars, very likely has other interests and hobbies.
So what, while local experience may differ, GM seems reasonably willing to replace engines when they drop valves under warranty. It's more a matter of their having done enough lifecycle testing to think there's enough of a chance it will not need a $17,000 free engine replacement to sell it in the first place. And there are things I don't like about GM, but I like my corvette, and I can't afford the same level of performance from a brand that has a life time warranty, actually does anyone have a better manufacturers warranty for equal or better performance?
That warranty is based upon GM's analysis as to their risk.
That can be impacted by a number of things aside from stoutness and durability.
We already talked about on track incidents, propensity towards storage in parts of the country, and average owner's use during the time while the warranty is in effect.
LS6's had similarly constructed valves, point that they can be reliable. I would have considered that they took what they learned by running the LS6 program, plus a number of years working on the LS2, LS3, LS7, LSA, and LS9 sorting out the valve trains (and yes I know they are not all the same).
And it's part of the reason why I don't believe that GM is going to tell us all that there is to know about this matter.
Well, in the early years it was blind luck, then that became rule's of thumb, lately probably a lot more simulations are getting run in a box of rule's of thumbs, with a dash of luck thrown in.
With regard to your last paragraph, it goes back to that which I talked about earlier, with regard to "time", but it also goes to how I plan to use the car during that "time".
I don't expect to get 100,000 miles out of a cammed car.
I have other vehicles to drive, and do not drive this car to work.
My car currently sits today at
It was purchased in August of 2007. So you can see, I really don't put very many miles on it. So, what's that, about 3,200-3,500 per year or so. In Westerrn Pennsylvania, where the winters are long, and the snow and ice can wreck havoc on the roads, that's about all I'm going to get to drive it.
Of that some of the miles have been occasional trips to the drag strip, it might see a drag strip rental or two over the year, and a test and tune or two, or to the local road course for HPDEs. But trailering it and taking it to the track, is hardly a weekly thing for me either, even though I own a trailer.
But that said, I expect it to last during the period of my ownership, the way I use it, regardless of miles. And I expect it to hold up during those times when I do track it.
When it was stock, I had no confidence in it doing that.
Plans: Really, I don't know just yet. I don't see myself getting rid of it, and I don't really like the new ones. And considering my other hobbies, guns, golf, sports, well, like the rest of my "toys", I want it to be reliable when I go to use it.
#1075
except for the valvetrain mods, i'm bone stock. didn't even port the heads because i wanted to stay pretty much stock from the engine perspective, but if i track the car, i'll probably do the EGT sensor to be comfortable. hell, i may do it anyway just to satisfy my curiosity though the pig rich stock tune should should be Ti friendly.
#1076
With success defined, what proof do you have to say it's met that standard?
#1077
Why would I need for it to last any longer than that?
If it's still running when I get rid of it, then who can argue?
#1078
Perhaps it's just a lack of paranoia
#1079
I can tell you this though, when the work was done on my car, there was some galling and coking of the exhaust valves, and a couple of the guides were out of spec. So even with the low mileage that was on it when the work was done on it, I'm convinced that what I did, may well have saved, and probably did save my engine.
That 23,666 that you see, I don't think it makes it that far had I done nothing.
And the reason why I don't think so, is because there are other cars in here which have failed before reaching even that point, and currently knowing the condition of my heads and valves which were removed.
BTW, and out of curiosity, I see that you are right up the road from me in Ohio. How many miles do you have now and how many do you put on it per year?
#1080
if looking at it with failure statistics, a statistically significant difference between the failure rate at a given mileage for the fixed heads vs. the failure rate at a given mileage for GM produced heads during the build dates where there is an issue (which as far as i'm concerned is 2006-present?). this is for stock. stock cam, stock tune. also, desirable to control for track days. statistically significant can have several defns. it could also mean moving the failure rate curve up some significant number of miles. all while no measurable decrease in performance. for guys with cams, the measurement would need to be different. we haven't yet made it there with statistics, but keep collecting and we may be there in a couple or few years. << not being sarcastic; i think it'll be a few years for the failure method of measuring, and that assumes this thread continues to gather data.
