[Z06] How Many Z06 Owners Are Running Solid Stainless Exhaust Valves?
#1381
Are you saying that it couldn't be????
I'm taken aback though as to why you ask, as I thought this was commonly accepted as a possible potential contributing factor in the decrease of reported incidents and a key step in the overall management of the issue.
#1382
Well, after reading what others have had to say about the issue, yes, it appears, at least to me, that it can be.
#1383
Cheers, Paul.
PS. And I rest my case because based on post#1393 it looks like were back to the theory of spontaneously combusting exhaust valves because unless you can prove it with your own thread, bad guides are apparently not necessary for the sort of valve failures the LS7 has been experiencing.
#1384
Good luck. No one has proven yet that "worn guides" are a consistent pre requisite for a dropped, hollow stemmed stock, inconsistent valve stem wall thickness, LS7 exhaust valve.
And yes, the stock exhaust valves....well, they have already been described by among others, a supporting forum vendor in here no less, as having varying and inconsistent wall thickness. Even if that vendor won't openly disclose, and refuses to discuss, their apparent "proprietary" techniques utilized for determining this, I still respect their findings in light of the documented failures described right in here.
I would also add that I accept and respect their right of refusal to discuss, or disclose the actual methods they used to determine that which they claim to have found, and accept any such reasons whatsoever they give for refusing to discuss their techniques. That's their prerogative.
But all of the above said Hauls, I would be very interested, very interested my fellow forum member and Corvette brother, in knowing what the stem to guide clearances were in each of the cases of stock exhaust valve failure we have seen described in here, and I'll be looking for the thread.
#1385
Just got my heads wiggle tested and every valve is out of spec intake and exhaust. I'm running stainless exhaust valves on stock guides. 26k miles on stock ported heads. Some way way out of spec. There is no doubt in my mind if I still had stock ex valves in there I would have already dropped a valve.
I plan on replacing them ASAP and won't drive my car until I do. I already have a set of stock cores I'm going to send off shortly.
#1386
Those powdered metal guides can wear out fast once the wear starts.
At least your valves were strong enough to keep you from suffering a very expensive mishap.
#1387
#1388
Seems that tons of guys with LS7 also trust his opinion. He recently processed 9 sets of LS7 heads in 5 days. And he reports that many other guys are moving up to the All Pro and Brodix heads, none of which run the stock OEM exhaust valve.
DH
#1389
I just went up and added you, and good luck with the rebuild. You definitely dodged a bullet as your valves held together until you could first identify that you had a problem, and that is a good thing.
This could have easily gone the other way had you still had the stock exhaust valves in it. We would be reading about your dropped valve incident, and you would be shoping for a new crate motor right about now.
Instead, you are only looking to have your heads done.
Big price differential, without a doubt.
#1390
Who re-worked your heads originally, and what precisely did they do?
#1391
I'd like to hear how our resident gurus or their best buddy Richard go about explaining how SS valves managed to wear out a bunch of valve guides when that wear is KNOWN (at least to our gurus and WCCH) to be the responsibility of the stock OEM valve
Cheers, Paul.
#1392
At the very least, we know that he was on stock guides and running SS valves with them.
So that tells us that either someone installed new SS valves into his old stock guides, which has happened in here before I might add, and with similar results....or someone put in new stock guides with new SS valves. Another questionable approach if not an outright boo boo from all indication thus far.
Across the discussions in here, and across the continental United States, it thus far appears that new manganese bronze guides and SS valves are the usual manner in which this issue is typically addressed in the LS7, and a manner which has thus far proven to be successful.
Bronze guides are said by at least one forum vendor, in an exchange with one of our forum members, to have better wear characteristics:
Okay then, I'm gunna have a hard time reconciling your experience with what Brian Tooley had to say on the subject...all be it his opinion seemed most directed towards street so maybe we can't assume what works for a race car will automatically work for a street car???
Powdered metal versus bronze guides
As many of you know I owned Total Engine Airflow from 1993 until 2004 when I sold it to Summit Racing and then worked with the guys at Trick Flow Specialties until 2010 where I developed every CNC program they have, as well as worked on new cylinder head designs. Of the dozens and dozens of used aftermarket heads with bronze guides that came into my shop using stock rockers, the number of heads that had what I would consider excessive guide wear (over .004”) was 100%.
There is no comparison in hardness between powdered metal guides and bronze guides. Powdered metal guides are far harder, and since they’re engineered with silicon they have good lubricity properties. I’ve checked OEM LS guides from a truck with 150,000 miles that only had .0001” of wear. Bronze guides when using stock rockers is a poor choice in my opinion, simply based on the guide wear that I’ve seen in my years of experience. I’ve seen bronze guides with 10,000 miles have .010” wear. Most shops never have the opportunity to check this. I’ve seen heads with no oil consumption or any other obvious issues have .010” of guide wear, this is a testament to how good modern valve seals are.
Bronze guides don't wear as quickly as PM guides. Bronze guides appear at this time to fix the problem and as I say we're monitoring it. I can say we're looking at other improvements to the valvetrain system, but rocker arms are not one of them....
Somebody is making the connection between valve guide wear and alleged valve failures. We are not making that connection as we can't confirm it. We're not seeing valve failures. I don't know what the root cause of these stock engine failures is because we are not evaluating them.
No chance. I really think this is being blown way out of proportion and people with stock engines don't have much to worry about. I myself have a high lift cam and stock valve guides and valves. I have no fear in driving it. In the future I would like to change to bronze guides, but it's not stopping me from enjoying the car
#1393
[...] Across the discussions in here, and across the continental United States, it thus far appears that new manganese bronze guides and SS valves are the usual manner in which this issue is typically addressed in the LS7, and a manner which has thus far proven to be successful.[...]
#1394
I ask because I have seen no indication in here that it isn't, and I know that there is indication that you are currently in the process of addressing this issue in your own car, and thus your information as to what professionals are using and doing might be more current than my own.
If you know of more current information with regard to this matter, specifically with regard to which professionals are using what when it comes to valve guides, and what type of success they are having with these choices and over how long, well then I request that you indicate so in the thread.
Thanks for your assistance and your anticipated write up and input into the thread in this regard Mark2009.
#1395
wiggle test
#1396
#1397
And why are you discussing this non forum sponsor anyway?????
Well, actually it took no effort on my part, so no thanks is really needed.
#1398
That's VERY strange as WCCH is the only company I know that you can get the upgraded CHE bushed rocker from...
#1400
The guides used in "The Fix" are not always C.H.E. guides.
Si Valves, made the guides in mine and in at least one other set of heads that I know about.
http://www.sivalves.com/ocantique_vguides.html
